4x100 Wheel spacers with 72.6cb?
  • fastfish
    • Jan 2020
    • 7
    Hey Guys!
    I have a set of 16" BBS style 5's that I had filled and redrilled to 4x100. I know I want/need 15mm spacers but I'm having trouble figuring out the best way to get from a 57mm cb to 72.6mm cb.
    Any suggestions?
    Thanks
  • TobyB
    • 5288
    I forget how deep the E30 centering bore is, but you may need something more like 20mm to be able to reduce the center bore that much.
    There needs to be a lip over the E30 bore to support the centering diameter, and the E30 bore is pretty deep.
    I would measure and make something on the lathe.
    Or I would bore the wheel out to the BMW bore.
    I don't mind spacers, personally, but they do require a bit more care than wheels that don't need them.
    t
    • JRHemmen
      • Jul 2018
      • 202
      You can run hubcentric ring adapters, but if you're going to need a spacer I'd suggest just getting spacers made to order. Fitment industries does this, but I just ordered a set from https://www.motorsport-tech.com/. They won't ship for a few weeks so I can't speak to their quality but I've seen them recommended in a few places. Spent like $160 for a set of 4. These will adapt from the E30 hub bore to the Style 5 bore.
      • zadma
        • May 2020
        • 4
        Our hubcentric spacers come prepared to fastener on, which all high pliable studs and open finished nuts or screws as required. These spacers are 100% 6082 billet aluminum, utilized for its weight and quality and processed from one bit of aluminum to guarantee accuracy of fitment.
        Tutuapp 9apps Showbox
        • hopeful
          • Dec 2012
          • 118
          wth is this?
          • reelizmpro
            • 9557
            I've found that using regular spacers with hubcentric rings gives you more flexibility if you change wheels though and is often cheaper.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
