Valve cover gasket.
  • 84mint325e
    • Feb 2020
    • 56
    Valve cover gasket.
    Hello Members, I own a 1984 BMW 325e with a 2.7 liter engine. What is the best valve cover gasket manufacture (besides BMW) out there. I already have four new rocker shaft plugs. Thank you
  • daveduck
    • Dec 2015
    • 88
    I've always heard the Victor Reinz is terrible, so stay away from that at least. I think the Elring one is good enough. My advice is to check out FCP Euro, they generally don't stock poor quality parts, so you can't really go wrong.
    • 84mint325e
      • Feb 2020
      • 56
      Thank you Dave. When you change your valve cover gasket, do you use a thin layer of RTV silicone on both sides?
      • Vincenze
        • Apr 2019
        • 1031
        The OEM valve gasket often leaks oil.
        Victor Reinz's gasket actually has an additional rubber layer.
        https://www.ecstuning.com/BMW-E30-32...h/11121730229/
        I would use silicone on both sides.
        Again, Victor Reinz's Reinzosil is good.
        I would also use silicone around the rubber plugs.
        But it's relatively easy to change the valve gasket later on if it leaks.
          • 34844
          they've probably changed over the years. the VR gaskets in the past never had the silicone layer, it was just rubber and never sealed right.
          • Vincenze
            • Apr 2019
            • 1031
            I looked through different valve gaskets.
            Most of them, including OEM, are made of cardboard-like material. Silicone really helps with them.
            Some people say that the Goetze gasket is better.
            • 84mint325e
              • Feb 2020
              • 56
              Thank you for the information. I installed MAHLE (with that extra rubber layer) and it's leaking.
              • Vincenze
                • Apr 2019
                • 1031
                I would clean the surfaces from oil, and reseal the gasket using any high-temperature silicone.
                And the plugs too.
                • 84mint325e
                  • Feb 2020
                  • 56
                  Thanks Vincenze, I didn't think about the high temperature. The stuff that I was going to use would have burned away.
                  • 84mint325e
                    • Feb 2020
                    • 56
                    New gasket wit high temperature RTV did the trick. Thank you.
