making the front wheel centered?
  • Cabriolet
    • 9620
    Is there another control arm that would push my front wheels farther forward?
    the PO put stock e30 steel control arms and discarded the aluminum ones. should the wheels be this far back or is it normal? to me it looks like they are an inch back.
    Much wow
    I hate 4 doors
  • ak-
    • 12422
    Could he of put stock e30 centered control are bushings instead of offset?
    I know the M3 has a bit of a whacky front wheel centering too iirc.
    1991 325iS turbo
    • Holland
      • Nov 2008
      • 7212
      Treehouse Racing CAB's would fix that easily. Not the least bit practical for daily driveability.
      Originally posted by DEV0 E30
      • tonerrrr
        • Jul 2011
        • 935
        I thought them not being centered was considered normal.
        instagram: @tonerrrr
        High resolution E30 Fuse Box 300dpi PNG
        • Cabriolet
          • 9620
          It has Poly M3 CABs on it. that was the first thing i checked when i noticed it.
          Much wow
          I hate 4 doors
          • BillBrasky
            • Dec 2008
            • 1641
            Cabriolet, what is your build date? Early M3's had the standard steel control arms and yes, that amount of caster is perfectly normal on an M3.
            • Todd Black 88
              • Oct 2007
              • 3449
              Normal for an m3.
              97+e36 m3 control arms will move it more, if that's what you want.
              Originally posted by codyep3
              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
              2001 silver/Blk 325 cabby. SOLD
              2002 325xit Sil/blk. SOLD
              2010 F650gs twin
              • Cabriolet
                • 9620
                Originally posted by Todd Black 88
                Normal for an m3.
                thx
                if i choose to do this, are there any drawbacks?
                Much wow
                I hate 4 doors
                • pilotskillse30
                  • Dec 2006
                  • 1957
                  e30 m3 CAB push the wheel forward...its better for high speeds, I have them on my vert and they are forward not aft. You might have an issue with those poly's
                  here is before the e30 CAB's
                  • markseven
                    • Sep 2006
                    • 5327
                    This is incorrect. You may have installed your CABS 180° opposite how they should be.
                    I Timothy 2:1-2
                    • Cabriolet
                      • 9620
                      I have M3 cabs installed and it still sits that way. it looks like it just might be something i have to live with
                      Much wow
                      I hate 4 doors
                      • reelizmpro
                        • 9558
                        Mark it's true, but they only do it by a small amount using the OEM M3 offset mounts. With the control arm as a right angle pivot, if you move the CAB mounting point OUTWARD, it will move the other end (ball joint at the strut) FORWARD. The 96+ E36 arms will add more to it due to the design of the arm itself. Of course you want to make sure the control arms aren't bent in anyway as well. Buying new arms instead of just replacing ball joints eliminates this possibility.
                        88 M3 - LACHSSILBER
                        89 M3 - ALPINEWEISS II
                        • LJ851
                          • 7919
                          What?
                          Moving the wheel forward in the arch is exactly what M3 bushings do. The purpose is to increase castor which means the strut is more laid back.
                          If you do it at an adjustable upper strut mount you move it rearward, If you do it at the bottom of the strut you need to move it forward.
                          Lorin
                          The M30 is God's engine.
                          • RCM3
                            • Aug 2011
                            • 1304
                            Eric, my e30's wheel position today looks identical to yours. When I did the e30 M3 5-lug swap I installed new control arms and new Ground Control M3 offset CABs. I was replacing my stock 325iS 4 lug with e30 M3 OEM CABs. I noticed a movement of the wheel back (just like in your picture above^) , which I thought was odd.
                            -Ryan
                            05/87 Henna M3
                            04/71 Baikal 2002tii
                            • markseven
                              • Sep 2006
                              • 5327
                              Originally posted by LJ851
                              What?
                              Not sure then why most stock M3's front wheels are set slightly behind the wheel well centerline...
                              I Timothy 2:1-2
