making the front wheel centered?
  • fronton
    • Oct 2009
    • 1262
    As stated, the solution is 96+ M3 control arms. Treehouse cabs have the same offset as M3 cabs, just lower profile and stiffer so they will not change your castor at all.
    I do not know for certain why the M3's front wheels are not centered but a shorter wheel base allows faster turn in and steering response as well as a smaller turning radius, all good things in a sports car, even if it looks dorky.
    Other than the above and $400 for new arms, the only drawback is if you run larger tires and lower suspension. It is possible for them to rub in front of the wheel at full lock. This can be countered by running the stock suspension though.
    • markseven
      • Sep 2006
      • 5327
      Also, I have always considered the M3 CABS as camber bushings... meaning they add negative camber.
      I Timothy 2:1-2
      • Todd Black 88
        • Oct 2007
        • 3449
        They have nothing to do with camber, they do change toe slightly while increasing caster though.
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • markseven
          • Sep 2006
          • 5327
          I beg to differ, my good man.
          I Timothy 2:1-2
          • nrubenstein
            • 3148
            You can beg to differ all you want, but the real difference is in the caster. If anything, they will slightly reduce camber.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • markseven
              • Sep 2006
              • 5327
              Link?
              I Timothy 2:1-2
              • nrubenstein
                • 3148
                Link?
                Dude, what do you think happens when you rotate a triangle? It moves through an arc.
                • markseven
                  • Sep 2006
                  • 5327
                  Is that a no?
                  I Timothy 2:1-2
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    And you would be wrong then;)
                    2010 F650gs twin
                    • fronton
                      • Oct 2009
                      • 1262
                      M3 eccentric cabs only change caster if replacing non M3 centered bushings. Since OP already has eccentric bushings, the only way to increase caster angle is changing the arms themselves. For camber adjustment, he could switch to motorsport strut mounts but that will not address the wheel centering issue.
                      OP, the angle between the e30 M3 aluminum and e30 M3 steel control arms is the same.
                      • nrubenstein
                        • 3148
                        Is that a no?
                        No. I'm not providing a link. I'm pointing out basic geometry. The offset arms move the outer balljoint further off of perpendicular, which pulls them in.
                        In order to gain meaningful camber, you need to shift the OUTER balljoint out.
                        • markseven
                          • Sep 2006
                          • 5327
                          Thought so.
                          I Timothy 2:1-2
                          • markseven
                            • Sep 2006
                            • 5327
                            It certainly wouldn't be the first time.
                            I Timothy 2:1-2
                            • LJ851
                              • 7919
                              Geometry 101.
                              Lorin
                              The M30 is God's engine.
                              • kronus
                                • Apr 2008
                                • 13032
                                If I remember correctly, the aluminum e30 m3 CA's have the same geometry as the steel regular ones.
                                Cab, are your CABs installed right? Lorin's picture shows the correct way.
                                cars beep boop
