making the front wheel centered?
  • wilholl
    • May 2012
    • 518
    #31
    ^^^This is exactly what I am thinking^^^
    My wheels went forward slightly when I installed the M3 offset bushings
    as previously stated by others.
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
    • Cabriolet
      • 9620
      #32
      Originally posted by kronus
      If I remember correctly, the aluminum e30 m3 CA's have the same geometry as the steel regular ones.
      Cab, are your CABs installed right? Lorin's picture shows the correct way.
      yes, they are installed to the outside of the car, which pushes the wheel farther forward.
      it's an M3 it came with the M3 bushings
      Much wow
      I hate 4 doors
      • LJ851
        • 7919
        #33
        And M3 fenders which very much appear to have the wheel arch further forward compared to a vanilla e30.
        Lorin
        The M30 is God's engine.
        • reelizmpro
          • 9558
          #34
          I believe this is the real culprit since we are assuming the M3 wheel arch is in the same position as a regular E30 and therefore the wheel should be centered when it isn't. Aesthetically, it's one of the first things people notice about the front suspension on these cars. Keep in mind early 88's came with stock E30 CAB's from the factory so the problem was even more pronounced on these cars. Another explanation is of course...a bent control arm.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • markseven
            • Sep 2006
            • 5327
            #35
            Geometry 101.
            I'm wrong on the push forward, correct on the camber.
            I Timothy 2:1-2
            • markseven
              • Sep 2006
              • 5327
              #36
              This makes sense.
              I Timothy 2:1-2
              • LJ851
                • 7919
                #37
                I don't think you know what camber is.
                Lorin
                • markseven
                  • Sep 2006
                  • 5327
                  #38
                  Now your just being mean
                  I Timothy 2:1-2
                  • reelizmpro
                    • 9558
                    #39
                    With M3's everything was done with a purpose. Perhaps BMW designed the front fenders that way for the use of heim joints on the race cars and to satisfy the homologation rules.
                    88 M3 - LACHSSILBER
                    • golde30
                      • 11464
                      #40
                      What the fuck us going on in here.... Nobody here ever heard of camber/caster plates? How about an alignment with camber/caster plates? Jees...
                      IG: @Baye30
                      • fronton
                        • Oct 2009
                        • 1262
                        #41
                        Originally posted by golde30
                        What us going on in here.... Nobody here ever heard of camber/caster plates? How about an alignment with camber/caster plates?
                        Caster plates can't fix his wheel centering problem. They can change the angle of the strut but not the location of the wheel in the arch which is fixed by the control arm.
                        • nrubenstein
                          • 3148
                          #42
                          Your comments into his thread indicate that either you don't understand geometry, don't understand what camber or caster are, or some combination of the two. Unfortunately, you are adamant about your incorrect position.
                          But don't worry. I'm here to save you, not to judge. ;)
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • markseven
                            • Sep 2006
                            • 5327
                            #43
                            I'm pretty sure I admitted I was wrong about the caster.
                            So, I had some time to Google a little. Links:
                            From Turner:
                            "These bushings have the hole off-center to give your car a little more track, caster, and camber. This style came as standard equipment on E30 M3s (8/89-later)...
                            http://www.turnermotorsport.com/p-14...6-z3-pair.aspx
                            From VAC
                            Rubber offset bushing, as found on the late production E30 M3, are a great upgrade when replacing your original bushings on any E30 or E36. Appropriate for all vehicles and adds more caster and dynamic camber to your front suspension.
                            I Timothy 2:1-2
                            • LJ851
                              • 7919
                              #44
                              ^ Marketing hyperbole.
                              Simple geometry will show there is no meaningful camber change on a horizontal plane.
                              If you started at stock ride height, the laying down of the strut (castor change) would *very* slightly lower the car and the lowering would potentially add a minute amount of camber. We are splitting camber hairs here though.
                              Lorin
                              • nrubenstein
                                • 3148
                                #45
                                From Turner:
                                From VAC
                                http://www.vacmotorsports.com/catalo...s-e30--e36.htm
                                You know that there is a difference between static camber and dynamic camber, right?
                                Caster generally improves steering stability and *very* slightly increases camber gain (dynamic camber) under load.
                                I'm not sure why turner is claiming that they increase track. Most likely someone just typed that in without understanding it. The outer balljoint is already forward of the inner. Therefore, rotating it further forward decreases track, which also decreases static camber. It's very, very simple.
