Another 5lug option? | Now for the rear too!
  • mulberryras
    • 40
    #31
    Originally posted by Max399
    Yes, exactly. Also a bracket to allow you to use the caliper for larger disks.
    pm sent
    • rongineer13
      • 72
      #32
      Originally posted by kronus
      I think this is how it's meant to work: the inner half of the race slides on. The outer half threads onto the stub axle somewhat tightly, but doesn't get cranked down, then the bolt is threaded into it. The bolt presses up on the stub axle and locks the outer half of the race.
      If there wasn't such a bolt, I'm not sure how you'd lock the outer half of the race in place.
      Definitely a bit weird.
      Does the dust cap fit over the bolt arrangement?
      I agree that solution is a bit weird, especially considering the fact that the factory torque spec for the front nut is a little over 200 ft/lbs and the bearing needs that torque in order to be proper and not wobble about at speed...I really don't see how a smaller bolt tightening against the nut and spindle end will suffice.
      My 5 Lug Conversion Kit thread: http://www.r3vlimited.com/board/showthread.php?t=265863
      5 Lug Conversion Kit Group Buy!! http://www.r3vlimited.com/board/showthread.php?t=281362
      • wazzu70
        • Jan 2005
        • 1143
        #33
        Exactly!
        -Nick
        M42 on VEMS
        • kronus
          • Apr 2008
          • 13032
          #34
          I'm not sure I'm right actually. would like to know more about assembly of it. op?
          cars beep boop
          • Max399
            • Feb 2013
            • 991
            #35
            Ok guys, got the adapters on my hands right now, here is a link of the pictures i took, i think it should explain everything.
            A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
            If theres any questions left - ask :)
            5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
            Leave feedback about my transactions!
            • Max399
              • Feb 2013
              • 991
              #36
              Ok, so got more info, the bearing-holding nut has to be tightened the same as stock one, ie 210 ft/lbs, where as the M16x1.5LH nut - is a locking nut, it is tightened in the other direction. The manufacturer told me that most people don't even use the locking-nut, they just glue the bearing nut, but just to be sure they recommend using the locking nut.
              • wazzu70
                • Jan 2005
                • 1143
                #37
                Do you have to remove the dust shields for this to fit? I held up an E46 325i rotor I had to the front hub and it interfered with the dust shield before anything else.
                Just curious, but ditching the shield is not a big deal.
                -Nick
                M42 on VEMS
                • Max399
                  • Feb 2013
                  • 991
                  #38
                  Yes, unfortunetly the dust shield has to go.
                  • Eydreeyun
                    • 584
                    #39
                    Saw this in FS section. Did anyone try your product yet? I'm interested as I have e36 m3 rotors and calipers, but want to see reviews first.
                    • Max399
                      • Feb 2013
                      • 991
                      #40
                      Currently one set is on the way to US, so hopefully we will have a review and installation pics ;)
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5284
                        #41
                        I don't know how I missed this. Excited for reviews/install details
                        Originally posted by priapism
                        Originally posted by shameson
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          #42
                          Note the OP says non-m3 e36/46 brake options.
                          • Max399
                            • Feb 2013
                            • 991
                            #43
                            Exactly. M3 ones will not fit.
                            • einstein57
                              • Jun 2007
                              • 10780
                              #44
                              Ever get an answer to my question?
                              www.gecoils.com
                              • Max399
                                • Feb 2013
                                • 991
                                #45
                                Im really sorry, i forgot to PM you back. The answer is no, it is not currently possible to make the sleeves work with e28 bearings. E36, E46 only.
