Another 5lug option? | Now for the rear too!
  • wazzu70
    • Jan 2005
    • 1143
    This is a good solution that has been around a long time in various forms. It keeps correct E30 geometry is cost effective. Also the non-M brakes are a bit lighter too :)
    -Nick
    M42 on VEMS
    • Max399
      • Feb 2013
      • 991
      I'd say that its also a lot cheaper than getting all the M gear. ;)
      And its really hard to get it here where i live :)
      5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
      Leave feedback about my transactions!
      • wazzu70
        • Jan 2005
        • 1143
        Very true, and you can also run more wheel choices :)
        Can you ask why the spindle is split in two? I have always wondered why the spindle is not the full length of the bearing and the nut was not just on the end. Obviously the nut would need to extend to the threaded portion of the original spindle with a slightly smaller diameter than the original bearing surface to fit under the new bearing sleeve.
        -Nick
        M42 on VEMS
        • e30m3s54turbo
          • Jun 2010
          • 3292
          What rotors and calipers is a direct fit?
          • Max399
            • Feb 2013
            • 991
            Thats because it is the best design in terms of tightening the bearing. Well easiest. And it will not damage the bearing while installing. If you would use a full length spindle, then when tightening the nut, it would rub into the bearing, where as in this design, it will rub in the second part of the nut, and will do no damage to the bearing.
            You can use any non-M rotors and calipers. Ie any E36 or E46 brakes are a direct fit.
            • kronus
              • Apr 2008
              • 13032
              I'm interested in a set.
              cars beep boop
              • iansane
                • 1343
                Possible to get without the caliper adapter bracket?
                84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                • Max399
                  • Feb 2013
                  • 991
                  PM'ed
                  Will ask :)
                  • 330SMG
                    • Feb 2007
                    • 172
                    Finally a non Frankenstein solution. Where do I get it?
                    One question , What keeps the nut from coming loose? Is the drivers side left hand thread?
                    1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
                    • Max399
                      • Feb 2013
                      • 991
                      PM'ed.
                      Actually i think the double-nut design should to the trick, ie you i think it will hold itself, but i will ask on that. About the right-hind - do not know, but it surely fits without any modifications.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Originally posted by yahh
                        Anything for the rear?
                        As mentioned, you can do the 318ti/z3 trailing arms, but you can also use e30m3 bearings and hubs.
                        john@m20guru.com
                        Links:
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          I still don't understand the point of the bolt and washer that is threaded in after the adapter. Doesn't seem like it actually does anything.
                          • Max399
                            • Feb 2013
                            • 991
                            Got them on my hands now, so regarding the whats holding it - you can bend the washer just like you would with a normal bearing install.
                            • AlexKing
                              • Jul 2012
                              • 62
                              How about you send me a set and i will test them to assure the wider R3V community that they can stand up to abuse?
                              • kronus
                                • Apr 2008
                                • 13032
                                I think this is how it's meant to work: the inner half of the race slides on. The outer half threads onto the stub axle somewhat tightly, but doesn't get cranked down, then the bolt is threaded into it. The bolt presses up on the stub axle and locks the outer half of the race.
                                If there wasn't such a bolt, I'm not sure how you'd lock the outer half of the race in place.
                                Definitely a bit weird.
                                Does the dust cap fit over the bolt arrangement?
                                cars beep boop
