Rotor set screw
  • BS87
    • 1606
    Rotor set screw
    Needs to be replaced every time, correct? Searech turned up nothing, oddly enough.
  • Jordan
    • 12916
    Only if something is wrong with it.
    https://mtechniqueabs.com/
    • BS87
      • 1606
      Thanks, figured i'd just check.
        • 34844
        they tend to rust/strip, and they're cheap, so no reason not to replace them..
        • BahnE30
          • 1050
          don't need it, lugs will hold it on there fine. i don't know of anyshops that actually put them back in when rotors are done, they're a pain in the ass to get out next time anyway.
          • DanGillan
            • Mar 2004
            • 4061
            you're a moron, if shops arent putting them back on the shop is a hack piece of shit. they're there for a reason.
            Dan
            • alex
              • 2024
              Antiseize baby!
              I betcha you'll have a hell of a time trying to start your lug bolts if your rotor is:
              -1- not staying in place trying to fall of
              -2- staying in place, but rotating as you rotate the wheel making it quite an interesting affair.
              I think the above 2 should make it worthwhile to put that screw back in. As I mentioned use antiseize and hand tighten it only.
                • 34844
                that's because they're too lazy and too cheap to buy 50 cents worth of screws..
                • Dave
                  E30 RAT
                  • 11675
                  PB Blaster, 5 mm allen wrench. What is so hard about it?
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    If its just hand tightened it should be purdy easy to loosen it by hand as well with the 5mm allen wrench.
                    Will
                    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                    Welcome e30 (brilliantrot '90 325is) 12/23/06
                    DaveCN = Old Man
                    My signature picture was taken by ME! Not by anyone else!
                    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • DarkWing6
                      • Apr 2004
                      • 7144
                      Don't new ones come with the rotors? They came with mone. If not they cost like $.25 each. I know R3Vers are cheap, but come on guys.
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        PFFFT.
                        Dremel and a flat head, no problems.
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • rwh11385
                          lance_entities
                          • 18403
                          Replacements came with my brembo rotors. Used PB Blaster and had no issue. Put anti sieze on them before replacing. Help keep rotor on their so you can get your wheels on.
                          • Ryan Stewart
                            I Love Miatas
                            • 8978
                            Dude, new ones are bullshit. Ill sell you my used ones for 20 cents +shipping.
                            Im now E30less.
                            • rwh11385
                              lance_entities
                              • 18403
                              I have four used ones as well. $.15 each + shipping.
