Best aftermarket solution for front disks?!?
  • a3ternus
    • 643
    Well,I m soon gonna change my front disks and would like to improve my cars braking a bit so i may opt for aftermarket disks...
    Any good suggestions that are maybe cheaper or of equal value to the OEM ones (which i can always find at a junkyard or anything like that!) ?!?
    Thanks in advance...
    N.
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
  • ///M Powered
    • Jan 2004
    • 1109
    I'd like to hear some suggestions as well, since any kind of rotor would be an upgrade. ( 318i brakes are horrible)
    • 318driver
      • 1714
      ATE power discs are what many people use. Cheap. I like mine
      90 325is
      IE stage 3s and refeshed m20....
        • 34844
        I have ATE power disks too. they're over 25,000 miles, pagid pads and the rotors aren't even half worn. that's with a heavy car, high speed freeway driving and several autocrosses.
        I thought they needed replacement a while ago, but it just turned out that my brake sensor was rubbing on the rear wheel. oh well, it's less than $100 for both the pagids and ATE rotors at BMA.
        • a3ternus
          • 643
          Nice,i ll check if i can find these here in Greece! :) N.
          • Bavarian3
            • 1230
            Balo rotors...
            • Jon325i
              • 6934
              Originally posted by Bavarian3
              Balo rotors...
              Very good OEM spec replacement. If slotted rotors are what you're after, you can't go wrong with Ate PowerDisc. Very cost-effective upgrade for the E30. And anything other than OEM pads is an improvement too.
              Just for the record....
              http://www.eap4parts.com has Ate PowerDiscs for '84/'85 318i are $36.95 each. They do not carry Balo rotors for that year/model E30.
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • ///M Powered
                • Jan 2004
                • 1109
                Thanks for the link Jon 8)
                • parkerbink
                  • Jun 2004
                  • 10138
                  I really like my ATE Powerdisks. They were cheap and work great!
                  • Skafrog
                    • 1732
                    the best upgrade you can do for your car is to change the fluid, get vented rotors if you dont already, use solid face rotors, and good street pads (Hawk HPs or Ferodo DS2500).
                    NASA MidSouth TT Director / GTS2 #018
                    Mods: Coastal PS Fluid, 10w40 Oil
                    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                    • demlotcrew
                      • May 2004
                      • 297
                      Ferodo are very good but they stop making them for the E30 :(
                      Andrew AT E30zone.co.uk | H23-is | S14
