rear hardline fittings question
  • duct-tape
    • May 2013
    • 34
    I'm replacing the rotted lines and have gotten to the back end.
    My question, the 3-way union mounted near the subframe connected to the steel line from the front... is that a Tee union or a balance/proportioning valve?
  • FLG
    • Sep 2011
    • 3165
    Just a tee
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • jrobie79
      • Mar 2006
      • 2526
      t-fitting...cheap from the dealer new
      1991 318i ---- 308K - retired
      • noid
        • 1537
        Its a T, I hope your making bubble flares and using bubble flare unions.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • JGood
          • Jan 2004
          • 7959
          Last I checked (last year), they were NLA.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • Cyrix2k
            • 593
            yeah, I tried to order one and was shot down. It's brass (?) so it doesn't rot anyway.
            1997 540i/6 - stock
            1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
            1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
            • JGood
              • Jan 2004
              • 7959
              Yep, usually they are salvageable. I needed one to split my front brake line, it's surprisingly difficult to find an m10x1.0 bubble flare 'T'. No car manufacturer besides BMW seems to use them.
              • Striker01
                • Jul 2011
                • 379
                Will this work?
                3 way Tee 10mm x 1.0 female European, metric, tee DIN flare (bubble/ISO) This tee is brass Use with 3/16"/4.75mm brake line
                • JGood
                  • Jan 2004
                  • 7959
                  Only if you use double inverted flare tube nuts on it, won't work with factory bubble flares. It would work fine, but some people may wish to keep everything uniform on the car.
                  • Cyrix2k
                    • 593
                    +1. If you use that, put a tag on the fitting with a note.
                    1997 540i/6 - stock
                    • Striker01
                      • Jul 2011
                      • 379
                      Didn't realize it was the wrong type, I thought that "(bubble/ISO)" meant it would work.
                      • noid
                        • 1537
                        He linked to an ISO/Bubble flare union, why would you want double flares going into your bubble flare union
                        • SkiFree
                          • Jun 2011
                          • 2766
                          Not sure what part numbers you guys are using but I've got a bucket full of new ones out back.
                          ADAMS Autosport
                          • duct-tape
                            • May 2013
                            • 34
                            I appreciate ALL this. way more than I expected.
                            Since I'm replacing every inch of brake line on the car, I'll probably go with a more standard fitting.
                            • JGood
                              • Jan 2004
                              • 7959
                              Apologies, I confuses DIN for the inverted flare.
