Rear trailing arm. Material? Can't weld.
  • Panici
    • Dec 2009
    • 2573
    Hey guys,
    Trying to weld some spring centering pieces to my rear trailing arms. I can't get the welder to work.
    Measurement between a clean, shiny ground and my clean, shiny perch is over 10Mohms on a multimeter.
    Are the trailing arms made of some odd material? Should I be looking at high strength bonding agents.
    Help!
    (I've cleaned these off more since this picture)
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    no thats just rust
    88 325is Five Speed
    Lachssilber
    • nrubenstein
      • 3148
      Your problem is that you should be throwing those in the dumpster.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • dewme5
        • Mar 2014
        • 165
        That is complete junk. In the picture, what you are calling clean, is just polished rust scale. Scan the classifieds, get some new rust free ones. And please don't learn to weld on suspension.
        • Panici
          • Dec 2009
          • 2573
          I didn't know it was possible to polish rust scale?
          That picture was when I first started cleaning them up. They were a LOT cleaner when we attempted to weld tonight.
          I wasn't the one welding. My friend who has plenty of welding experience was.
          I found a set of better condition ones. Going to pick them up tomorrow morning. Anything I should keep in mind when swapping them out?
          • jalopi
            • 2370
            The only way those arms are coming clean is with electrolysis. Worked quite well with my arms, though yours are 10x worse. Probably take a few days in the tank to get all that off.
            • Panici
              • Dec 2009
              • 2573
              Threw some 2-part Epoxy at them last night.
              I don't expect it to work, so I also just came back from picking up a used set of trailing arms.
              • ForcedFirebird
                • Feb 2007
                • 8300
                Your friend has welding experience and actually tried welding to that?
                john@m20guru.com
                Links:
                • dewme5
                  • Mar 2014
                  • 165
                  Since you are in there, I would paint and put in new bushings.
                  Sent from my HTC6435LVW using Tapatalk
                  • e30_302
                    • Sep 2013
                    • 453
                    That's nothing a grinder can't fix.
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      except adding material.
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
                      • Panici
                        • Dec 2009
                        • 2573
                        As I said before, I cleaned up the area much better after that picture was taken.
                        Somehow I polished the rust scale and it looked like shiny metal, even under flashlight.
                        My thoughts exactly.
                        If my "cold weld" epoxy holds for a few months until I put the car away for the winter, I'll drop the subframe and do it all at the same time.
                        • jalopi
                          • 2370
                          lol wut, please tell me you didn't use JB weld on that spring perch
                          • Jean
                            • 18228
                            find some good used set.
                            • Panici
                              • Dec 2009
                              • 2573
                              It's not JB weld.
                              Apparently this stuff is used to fix cracked engine blocks, among other things.
                              I'll check it regularly, I can always throw on the trailing arms I bought if need be.
