Ireland subframe bushings. Is this all I need?
  • RenaissanceMan
    • Aug 2004
    • 237
    About to replace the worn out subframe bushings on the E30. I have this pair of Ireland engineering subframe bushings that I'm going to be replacing them with. Are there any other components, bushings, washers, etcetera that I need to do this job or is it literally just replace what's in there with these two piece bushings? Just don't want to get into the job and not be able to finish today. Thanks!
    Sent from my VS995 using Tapatalk
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4508
    Make sure you use washers on top.
    • RenaissanceMan
      • Aug 2004
      • 237
      Something like these?
      '90 325is/S52
      '76 2002
      '74 2002tii
      '06 325i sedan
      '05 X5 3.0i
      • RenaissanceMan
        • Aug 2004
        • 237
        On second thought, guess I will not be installing these. Look what happened when I just pulled one of them off of the post. Good grief.
        '90 325is/S52
        '76 2002
        '74 2002tii
        '06 325i sedan
        '05 X5 3.0i
        • Stanley Rockafella
          • Aug 2011
          • 4062
          Never had that problem with OEM rubber mounts....
          • RenaissanceMan
            • Aug 2004
            • 237
            I hear ya. May go oem with this car. Either that or AKG performance bushings. It is a street car with an s52, but can't imagine oem wouldn't do the job effectively. Oh well, won't be finishing this project today. [emoji20]
            '90 325is/S52
            '76 2002
            '74 2002tii
            '06 325i sedan
            '05 X5 3.0i
            • Kershaw
              • 11822
              That's the problem with poly. 5 years old and it disintegrates. It might be a stiffer material, but if you don't replace all your poly bushings every few years you're asking for catastrophic failure.
              I saw engine mounts do this as well.
              AWD > RWD
              • rturbo 930
                • Dec 2005
                • 2627
                Poly seriously only lasts five years? First I've heard that. I put those same bushings in about five years ago, but I screwed up the installation somehow and the subframe can move up and down about 1/4". I still need to fix it. If poly seriously only lasts five years, I'll replace with OE and be done with it.
                • superj
                  • Feb 2006
                  • 397
                  I have never heard that either. not saying its not true, just never heard it.
                  we put poly garagistic on my son's car a few months ago. that is all we bought and put in. everything else was fine and went back in like it came out.
                  I am going to put garagistic ones into my other son's, also. way easier to put them in that get those old rubber ones out, that's for sure
                  • Kershaw
                    • 11822
                    Search the internet for polyurethane bushings disintegrating. It's quite common.
                    AWD > RWD
                    • RenaissanceMan
                      • Aug 2004
                      • 237
                      So I ended up ordering oem bushings... This is a street car primarily so I figured they would be fine. Hopefully I won't regret the choice. ☺
                      '90 325is/S52
                      '76 2002
                      '74 2002tii
                      '06 325i sedan
                      '05 X5 3.0i
