Ground Control
  • D-rock
    • 714
    Ground Control
    What spring rate are you guys running and why?
  • E30SPDFRK
    • 5716
    300f 475r
    running them because that's what they had attached when I got them. Not a bad ride, old people complain but I think its nice.
    Switching it up to 600f 700r soon though.
    Byron
    Leichtbau
    • z31maniac
      • 17566
      BRonzit was 350/500 when I got it.
      After S52 was 550/750
      The 318is, not sure, I'd have to ask the PO or take the wheels off, but I'm wanting to say something in the 325/475 range I think?
      www.gutenparts.com
      • DRTSRFR
        • May 2008
        • 1836
        440/700 on my two coupes and 440/800 on the 'vert.
        For me this is the best combo for balance and comfort...firm but not harsh.
        Suspension tips here...
        http://www.r3vlimited.com/board/album.php?albumid=757
          • 34844
          rides fine except my konis are toast. time to rebuild them or upgrade..
          • White325is
            • Oct 2006
            • 5947
            And because I was running such a wide wheel/tire combo. Didnt want to rub.
            • george graves
              • 20003
              How did you come about to pick those rates? Just interested.
              Originally posted by Matt-B
              • z31maniac
                • 17566
                The 350/500 was on the car when I got it.
                The 550/750 came about after a few different conversations with Jay and Frankie at Ground Control. Explained the engine (S52), sway bars (22/19), tires that would be used (sticky 235/40/17).
                And came to those rates, but with no rear bar.
                www.gutenparts.com
                • rwh11385
                  lance_entities
                  • 18403
                  Car first had 300/475 - the setup GC has given a lot of street E30s.
                  Then I got a set of 500/650 - was a lot faster around Auto-X course, have not been on a roadcourse yet. Of course stiffer, and more bouncey, but I have a blown strut.
                  I'd go 350+ in front... with a 500 in back or so.
                  • Jean
                    • 18228
                    500front/650rear with no rear bar, worked great in autocross. sold it to to switch to higher rates with the engine swap and wider/stickier tires.
                    I will probably end up with rates similar to what z31maniac posted above.
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      350/475. I've been happy with it, but it may be a little too soft. I was told by Jay that the billies can't really handle much more than this though.
                      Project M42 Turbo
                      • Stephen
                        Шлем ишака
                        • 10774
                        300/500 and happy. If they come around at the right time i might bump up ro a 350 up front but its not really that big of a deal. Running fairly aggresive fitment as well
                        • z31maniac
                          • 17566
                          Good rates to be sure.
                          And you v710s will prevent the traction issues I was having!
                          www.gutenparts.com
                          • BigD
                            • Jul 2006
                            • 1085
                            550/750, because GC told me this is about the most the regular Koni SAs can handle while leaving a smidgen of adjustability. It feels fine on the track but it could definitely be better. After the turbo, I'll be doing a new suspension with 4 figure rates (front for sure).
                            • khnordeen
                              • Oct 2007
                              • 459
                              Are there any differences in the sleeves themselves depending on the shocks/struts that will be paired with them?
                              I am currently waiting on some Bilsteins in the mail, but some sleeves I have come across I believe have been paired for Konis...
                              I'd call GC directly, but they are currently closed...
                              Thanks for any help.
                              -Kyle
