Ground Control
  • Wh33lhop
    • 11705
    #31
    Originally posted by nando
    i do
    you can get away with stiffer rates if you have matching, quality dampers. where the ride sucks is when the dampers can't properly control the spring. I would think 300/500 would be too soft, the ride quality may actually be worse, depending on ride height and suspension travel.
    I wouldn't be lowering it that much to begin with, I'm trying to retain stock "junker" looks for the lulz. I've got some Konis, the fronts are Corrodo inserts, I think they'll work alright.
    I had 450/375 on my last car, which was about 3300lbs with me in it. Those weren't track car stiff but even with all the chassis bracing and the shortened Konis I had on it it would get a bit bumpy (and I wasn't even that low). I'd like to run 500# front or so (still learning about rear rates in relation to fronts because of the different motion ratio) with my 22mm front swaybar and M3 endlinks, but for a DD I don't think the ride will be too nice.
    paint sucks
    • Iain
      • Oct 2005
      • 2815
      #32
      I think you could do a true MacPherson strut rear-end in an E30 without too many hassles, but I'd DEFINITELY do a LOT of bracing of the tower.
      Pork Hunt Motorsport
      eBay is like the summit racing catalog for today's special Olympics crowd
      • tangkenboo2
        • Nov 2005
        • 799
        #33
        i'm at 550/700
        after the swap and new wheels i'm going 650/900
        reason: want to be slammed without rubbing
        [PAKSIW]
        20D .........
        vmwerks :up:
        ryan gmw :up:
        • z31maniac
          • 17566
          #34
          I had my swap car so low, it actually ride better on the stiffer springs.
          www.gutenparts.com
          • Holland
            • Nov 2008
            • 7204
            #35
            Jean, I think Holland was talking about a "true coilover" rear. In which the spring is no longer located on the trailing arm, but over the shock itself.
            Because of the difference in motion ratio, the needed spring rate will change, and serious reinforcement of the RSM area is recommended.
            You'll also lose of wheel/tire clearance with a true coilover setup in the rear.
            That's basically what I was wondering. Everyone says they got GC coilovers but I was confused by the rear being a true coilover or not but that doesn't seem to be the case. The reason I was wondering was because if they were indeed true coilovers in the rear I would need a rear strut brace for support and then I would lose the ability to have a removable stereo in my DD. That was my concern.
            Originally posted by DEV0 E30
            • D-rock
              • 714
              #36
              550/700 sound hard!
              I have 250/320 on my e90 and that was not bad but 700 my god!
              I will be slamming my e30 so i guess thats what i need.
                • 34839
                #37
                250/320 is like H&R race. lol. plus you can hardly compare an E90's suspension to the E30.
                • Jean
                  • 18228
                  #38
                  ^ +10. spring rates on different cars feel different
                  • s50e30m3
                    • Oct 2009
                    • 21
                    #39
                    question for a m3 e30 wth 24v I can use the spring rate of e36 front h&r race (345) and h&r e30 m3 race (570) in the back with billy sport what you think? i cant get to hi because of the bumpy roads and craters here in P.R. and i and planning to use skid plates to go lower
                    "because the E30 are the best car ever made"(OO=00=OO)
                    90' e30 m3 s50 proyect (10%)
                    96' e36 s50 318ti (parting out)
                    83' e21 320i m20b25 swap
                    94' drift machine e36 325i (turbo proyect in progress):hitler::up:
                    • D-rock
                      • 714
                      #40
                      Originally posted by tangkenboo2
                      i'm at 550/700
                      Are you rubbing with that set up! I feel thats what i want but that seems it might be to rough.
                      • tangkenboo2
                        • Nov 2005
                        • 799
                        #41
                        with 550/700 = only on hard bumps in the rear and full lock
                        with 650/900..i shouldn't
                        [PAKSIW]
                        20D .........
                        vmwerks :up:
                        ryan gmw :up:
