GC kit with bilsteins and koni sports
  • jaywood
    • Jul 2010
    • 4528
    #31
    I can have my dad do the welding, as long as it's steel...which it is right? And I think I'm going to get that $399 kit. What shocks are you running abby?
    • z31maniac
      • 17566
      #32
      Originally posted by jaywood
      Who here has the full GC coilover kit/and full coilover kit? And who has just the 399$ kit?
      Currently? No.
      But both my bronze S52 car and my silver 318is were both running the GC kits with specially valved Konis, shortened housings and camber plates.
      I plan on running the GC kit on my next E30 as well.
      I ran 550/750 rates with no rear sway on my bronze car.
      I believe 350/475 on the M42 with stock sways (not sure as they were on the car when I purchased it).
      www.gutenparts.com
      • ak-
        • 12422
        #33
        I'm running Bilstein Sports all around with a cut internal bump stop for that extra travel and Ireland Race plates to be lower and retain the same shock travel.
        What are you trying to do though? Function? Form?
        1991 325iS turbo
        • jaywood
          • Jul 2010
          • 4528
          #34
          More form then function. Not going to track the car or anything.
          • Philo
            Ich esse kleine Kinder
            • 3334
            #35
            If you're not going to track the car, I think spending a bunch of $ on a full coilover kit is a waste. Unless you are going for the adjustability and spring rate exchange, I see no need to get coilovers. Are you looking to slam the car?
            I think you'd be perfectly happy with something like a Bilstein sport/H&R Race setup.
            -tim
            Originally posted by Jordan
            I like the stance
            • z31maniac
              • 17566
              #36
              If you want slammed you also need the higher spring rates that you can get with coilovers.
              zimmie was having to run something like 700-800lb springs in the rear to keep his wheels from destroying his fenders.
              www.gutenparts.com
              • jaywood
                • Jul 2010
                • 4528
                #37
                It's my daily so being on the ground isn't my goal. I also don't want it lowered only an inch...adjustability would be nice so that's why I'm looking at the coilover conversion kit.
                I want it to be low enough to look cool and handle better but not so low that it's not drivable as a daily...
                • e30shmobberr
                  • 1934
                  #38
                  does anyone know the part number or model of the koni adjustables that will work with a shortened strut? i need to get them for my conversion kit ha
                  Patrick - IG:niicknac
                  RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                  • xwill112x
                    • Jan 2009
                    • 4236
                    #39
                    dude just get billy sports and H&R race, with some drop hats and no spring pads. I'm fucking slammed on that setup, and i love it. Perfect for a DD.
                    • Philo
                      • 3334
                      #40
                      /\ This guy is making sense.
                      OP, What would you use the adjustability of the coilovers for? Going to get out and turn the adjusters when you see a high-spot approaching? H&R race is about perfect for what you describe. Low enough to look good, stiff for the fun corners, DD'-able, can still make it over speed bumps, cost efficient.
                      -tim
                      I like the stance
                      • jaywood
                        • Jul 2010
                        • 4528
                        #41
                        You got me on that one....hahhaha
                        I don't know. I just like the idea of being adjustable, but it's not like I need it. Who here has a picture of an e30 with billy sports and H&R springs and maybe drop hats?
                        Where should I buy this setup?
                        • Philo
                          • 3334
                          #42
                          See sig. lol. Edit: And that is on 15s.
                          A lot of places sell them. I bought mine from zygmunt AKA this guy.
                          http://cgi.ebay.com/ebaymotors/SPEC-...#ht_500wt_1182
                          -tim
                          I like the stance
                          • jaywood
                            • Jul 2010
                            • 4528
                            #43
                            I already have bilsteins in the back, the PO put them on. It's all stock other then that.
                            Are you running just bilsteins and racing springs? Or did you take out your spring pads as well?
                            • ak-
                              • 12422
                              #44
                              Okay then screw everything and just do the kit. You will go pretty low.
                              Invest in some camber plates, and you will go low with more travel.
                              Invest in short body Koni's and some more strut modification and your pan will be sitting on the ground. Literally.
                              1991 325iS turbo
                              • jaywood
                                • Jul 2010
                                • 4528
                                #45
                                Where can I get the short body konis?
                                http://www.tirerack.com/suspension/s...ORT&perfCode=P
