Blown Strut After Track Day?
  • Danny
    • 14216
    Yeah that's what I meant. Fuck man, just get out there and do it. You can only learn so much reading on the internet.
    • McGyver
      • 4634
      oh, then use a screw driver and a BFH to loosen the collar. just dont tighten it on accident! the new inserts should come with a new collar and the tool for tightening it.
      • Dude
        • 1119
        There not reverse threads are they?
        The struts im putting in are used but in good condish so i dont have the tool.
        • McGyver
          • 4634
          ^IIRC they are normal threads. and i may have used a pipe wrench and a hammer to remove the collar... (it was a year ago)
          • Ian Bowers
            • Apr 2008
            • 1120
            They're standard thread, I just used a big ass pipe wrench.
            • accident
              • 7303
              i used channel locks. but pipe wrench works too
              Moral of this story?
              • Dude
                • 1119
                FFFFFFFFFFFUUUUUUUUUUUUUUCCCCCCCCCCCCKKKKKKKKKK
                Got both struts replaced, took her for a drive, problem didnt go away.
                Whats the symptoms of bad front wheel bearing? Or what else could it be? Feels kinda like the tire is halfway flat and theres a good little vibration through the whole front end.
                • dkbmxer002
                  • Nov 2007
                  • 1389
                  did you check your tire pressure? lol are you sure the new used struts weren't blown too?
                  • Dude
                    • 1119
                    Yes i did check it, but ill triple check it too. Gonna switch the front wheels to see if its the wheel/tire or if its the car.
                    And i mean the struts look in great condition and if you compress them they push back out like normal. The strut i pulled out wouldnt spring up at all.
                    • dkbmxer002
                      • Nov 2007
                      • 1389
                      how loose is the suspension now? can you easily pull the car up and down? were your bushings good?
                      • Dude
                        • 1119
                        Not sure what/where to look for bearing condition. The car feels solid while sitting, rocking the wheel back in forth didnt seem to feel loose at all.
                        • QUKBMER
                          • 8178
                          Did you say you put new or used struts back in and what brand are you using?
                          • Dude
                            • 1119
                            There used Bilstein Sports
                            • QUKBMER
                              • 8178
                              How many miles,is the front suspension soft when pushing down on it?
                              • McGyver
                                • 4634
                                if you have a bad bearing, their will be a noise and vibration that only increases with speed. how soon it starts depends on how bad the bearing is. it also usually gets worse/better if you turn hard in opposite directions.
                                Example:
                                bad front right. turning hard to the left puts more force on the right side of the car, so noise gets louder. turning hard to the right will lift the right side and the noise will go away.
                                also, you can jack the car up to turn the wheel and hear the scraping.
