list for suspension overhual/making camber plates
  • nickmp0wer
    • 1427
    alright so how does the rest of the stuff look, and what rear shock mounts?
    • Axxe
      • Aug 2004
      • 3355
      Originally posted by Brew
      You can dismount and swap them though.
      Of course, that is the only way to rotate direction tires.
      Keep it slideways!!
      • Borat
        • Jan 2005
        • 494
        well thats what he will have to do. Just rotate them whenever you do an oil change or something. A tire shop might charge $10-15 bucks a tire to flip them on there rims.
        Its only asymetrical that you can't flip on the rims as the have to be mounted on the rim a certain way, so not recomended if you have bad tire wear.
        • Jordan
          • 12911
          Which is what I call flipping....
          https://mtechniqueabs.com/
          • Dave
            E30 RAT
            • 11675
            good luck getting the rtrs rear subframe bshings - they are out of business. And it is their rear trailing arm bushings that were the good ones.
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • Dave
              E30 RAT
              • 11675
              Originally posted by Jordan
              After you make those you will see why you won't be able to make with more adjustement....
              Again... Just buy camber plates, they are cheap.
              I think I paid $270 shipped for them. Come on Nick. . . .
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Digitalwave
                is a poseur
                • 6282
                They will be back open in January under new ownership, and I am sure other places still have them in stock.
                Get some urethane TA bushings instead of stock ones Nick. And camber isn't as bad as people make it seem, you don't need camber plates. The rear is worse anyways.
                RISING EDGE
                • Jordan
                  • 12911
                  Tcamber isn't as bad as people make it seem, you don't need camber plates. The rear is worse anyways.
                  I got camber plates to get MORE camber in the front. Haha.
                  • nickmp0wer
                    • 1427
                    Ive heard that the urathane TA bushings squeek?
                    so are the sub frame bushings as good as others then?
                    and i would like to have more negitive at the track and fun runs on the twisties, but the car is still my dd and i would like to conserve my expensive tires
                    • Digitalwave
                      is a poseur
                      • 6282
                      No doubt, that's what they are made for. One of the best benefits of lowering an E30 is more camber. No camber sucks.
                      RISING EDGE
                      • Digitalwave
                        is a poseur
                        • 6282
                        Why would they squeek? RTRS is great stuff.
                        RISING EDGE
                          • 34839
                          they don't squeak. I've had urethane TA and subframe bushings for 3 years and I've never heard a squeak.
                          • nickmp0wer
                            • 1427
                            which did u go with?
                            • Jordan
                              • 12911
                              My IE trailing arm bushings did squeek after awhile. A quick relube quieted them down.
                              • erik325i
                                • Jan 2005
                                • 3567
                                I'm slammed.
                                I have no form of camber correction, front or rear.
                                So, you do have camber plates?
