taking out springs with no spring compressor 100% safe and quick/easy
  • grays
    • 1343
    #31
    hater get lost!
    • dothadance
      • Jun 2011
      • 1121
      #32
      Originally posted by e30jake
      I'm trina change my springs like this but my jack poped the tires
      lololol. i see what you did there.
      • LJ851
        • 7919
        #33
        Originally posted by grays
        hater get lost!
        You are barking up the wrong tree...
        Lorin
        The M30 is God's engine.
        • grays
          • 1343
          #34
          hey dont like my method then dont do it.. many others have done it this way without any problems. im not here to argue on a diy that has been done many times..
          • Jaxx_
            • Dec 2009
            • 1880
            #35
            Another member tried to use this method, he was never heard from again.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              #36
              Originally posted by deutschman
              I was thinking more like something Bill Caswell would have to do during the Baja 1000 in the middle of nowhere. Certainly nothing I want to try. I dont want a spring shooting into my face.
              Agreed. I was pretty much Trina explain to the OP that he should invest money an time into better solutions. At this ate h will bestowing his car with a chain and a motorcycle.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • KVF
                • 297
                #37
                This post is hilarious!
                I'd never work on a car without proper jack stands in place, but that aside, I have seen and helped people remove lowering springs in similar fashion. The key is to make certain you preload the spring by jacking up the control arm a slight bit, prior to loosening the top strut nut; enough that you compress the spring a bit, but not enough to lift car off jack stand. If you don't preload the spring, it will shoot hard at the jack and trouble may follow. Can't imagine that this would work on stock height springs though...
