Not low with race springs ?
  • Vincer325ei
    • Mar 2014
    • 488
    I have h&r race springs on my 87is my car Is what I consider stock height. Is there something wrong here ? Bilstien sports on the rear to.
    I am on 15's to. Have solid condor bushings and subframe mounts also don't think that affects it but someone help?
  • TheTacoMan
    • Nov 2011
    • 2308
    If they are brand new they will settle a little bit, also what size 15 tires are you running?
    • Vincer325ei
      • Mar 2014
      • 488
      Pretty sure they've been on about two years ish.. And 195/50
      • Mr. Tasty
        • Jul 2011
        • 3421
        definitely not stock height, looks like its lowered about an inch. Are you sure they are races and not sports? Are the springs black or red?
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • Vincer325ei
          • Mar 2014
          • 488
          Red up front and grey on the rear still has part numbers on the rear looked them up an race springs showed up I'll post a pic though
          • Vincer325ei
            • Mar 2014
            • 488
            Jk red in the rear to
            • Vincer325ei
              • Mar 2014
              • 488
              • ForcedFirebird
                • Feb 2007
                • 8300
                If you are using the stock strut mounts in the front, they tend to ride higher than expected. Put some camber plates on. The rear has a larger gap than expected because you have an early model.
                That is a spec e30 suspension, brows pics of them. The spring pads are usually removed (unless there for corner balancing) and they have camber plates.
                john@m20guru.com
                Links:
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  Your tires are way undersized at 195/50/15
                  195/65/14 is stock on 14" wheels.
                  205/55/15 is stock on m3 15"x7 wheels
                  I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                  2001 silver/Blk 325 cabby. SOLD
                  2002 325xit Sil/blk. SOLD
                  2010 F650gs twin
                  • Vincer325ei
                    • Mar 2014
                    • 488
                    Honestly believe this car was tracked at once. Has all the rite setup. Even had a toyo tires sticker on the dash and cutout and welded in metal coverings
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      What?
                      • Vincer325ei
                        • Mar 2014
                        • 488
                        What?
                        This
                        • Todd Black 88
                          • Oct 2007
                          • 3449
                          And this means what exactly? That your magic 195/50/15 tires are the same rolling circumference as a 205/55/15 tire because he car had a toyo tire sticker on the dash?
                          Hell even your speedo/odo will be out more than 5% at that size.
                          2010 F650gs twin
                          • Vincer325ei
                            • Mar 2014
                            • 488
                            Don't know what's up your ash, Didn't say anything about it being the same. Yes my speedo is off a good 15mph at some speeds.
                            • jalopi
                              • 2370
                              Looks about the same height as my POS, but you've got weeny tires on 15's so it's gonna look higher than what it is. Will look more "slammed" with a bigger wheel/tire.
