Not low with race springs ?
  • Best_name_available
    • Jul 2014
    • 479
    you're not going to get as low as you want on springs, especially not with an early model.
    Originally posted by Vokuhila
    I laughed, and then I serioused
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Why does a early Model have anything to do with it?
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • glnr13
        • 1334
        Originally posted by Vincer325ei
        Honestly believe this car was tracked at once. Has all the rite setup. Even had a toyo tires sticker on the dash and cutout and welded in metal coverings
        that panel means nothing.
        early models have higher rear arches so they always appear to have more wheel gap.
          • Jul 2014
          • 479
          thank you^^^
          • Vincer325ei
            • Mar 2014
            • 488
            People always jumping to conclusions on jere
            • Liquidity
              • May 2014
              • 395
              Like assuming the car is a track car because it has all the rite setup?
              • jalopi
                • 2370
                • Vincer325ei
                  • Mar 2014
                  • 488
                  So thinking hypothetically here a 16" wheel with say a 195/50 would be almost flush ?
                  • glnr13
                    • 1334
                    I think you're trying to fill the wheel gap, right?
                    flush is related to wheel offset.
                    195/50-16 isn't the most ideal tire size.
                    205/50-16 or 225/45-16 would be better and are still very close to OEM tire ratios if that's what you're going for.
                    • Vincer325ei
                      • Mar 2014
                      • 488
                      Yea just hate sitting looking stockish
                      • glnr13
                        • 1334
                        You could even do 205/55-15 so you don't have to get new wheels
                        • dirtbag30
                          • Apr 2013
                          • 678
                          sig worthy
                          just get the correct tire size, it will look alot better.
                          have you seen an e30 with stock suspension? yours looks fine, or will look fine with the right size tires.
                          you know some people spend good money to get their cars looking "stockish"
                          i have no idea what i am doing with my life
                          • jalopi
                            • 2370
                            Hrm, sounds like you need a set of 16x8 et0 wheels with 205/45's on em. Think you'd be quite pleased
                            • Digitalwave
                              is a poseur
                              • 6299
                              I'll buy the springs off you.
                              But your problem is the undersized tires.
                              RISING EDGE
                              • AndrewBird
                                The Mad Scientist
                                • 11898
                                You need to read this:
                                Wheel size has nothing to do with overall diameter. This calculator is also very helpful:
                                http://www.miata.net/garage/tirecalc.html
                                Your current tires are about 1-1/4" smaller diameter than stock, which means you will have about 5/8" more fender gap. A 195/60-15 or a 205/55-15 would be the ideal tire size, the latter being the most ideal.
