Koni/ Ground Control shocks Read Before Installing!
  • 2mAn
    SeƱior Mod
    • 21062
    so how was the ride with the stock strut mount and the GC/Koni setup?
    I need to check my Konis to see what size the top nut is, and also need to find the collars, but I think already... fun surprises. thanks for making this thread
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • AndrewBird
      The Mad Scientist
      • 11898
      Craftsman socket are overly thick. Other name brands tend to be thinner and fit fine. I have an off-brand set of deep wells that fit as well. Just have to find a socket that is slimmer, or buy one and turn/grind it down to fit.
      Oh, and the wrench they were talking about was probably something like this:
      This allows you to get an hex wrench in there to hold the strut shaft from turning. Technically you aren't supposed to use an impact, but I always have and haven't had an issue. :shrug:
      • KIRIEIW
        • Dec 2012
        • 3385
        I measured way back in the day, not even a thin wall socket is going to fit in this situation. The opening is just too small no mater what you do to tighten that 22mm top nut using the stock top mounts.
        2Man, had no complaints with the set up at all. Eventually I did pick up a set of GC camber plates though. Really the only reason I picked them up was for the simple reason that the camber plates lower your car an additional 12mm in comparison to the normal top mounts (well plus you can adjust the camber to get a little less tire wear).
        1992 e34 Touring- S50 Swap
        1992 325i-S50 Swap (SOLD)
        1991
        • 2mAn
          SeƱior Mod
          • 21062
          But with Camber plates versus the regular strut mounts aren’t you introduced a lot more noise and road feel into the cabin? Makes sense to ā€œtighten it upā€ for a race at but I’m aiming for a good street setup.... yes I could’ve done a spring / shock combo but my GC/ Koni coilover setup is almost the same price so why not? Plus I can fine tune the rates to perfectly suit me
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • me_john85
            • Jun 2018
            • 40
            Just to follow up, I used Sachs upper mounts PN 31331139452. They fit a 22mm socket just fine.
            • jeffnhiscars
              • Jun 2011
              • 6011
              If you read closely they are actually Boge-Sachs :)
              Alice the Time Capsule
              • KIRIEIW
                • Dec 2012
                • 3385
                Originally posted by 2mAn
                But with Camber plates versus the regular strut mounts arenƂ’t you introduced a lot more noise and road feel into the cabin? Makes sense to Ƃ“tighten it upƂ” for a race at but IƂ’m aiming for a good street setup.... yes I couldƂ’ve done a spring / shock combo but my GC/ Koni coilover setup is almost the same price so why not? Plus I can fine tune the rates to perfectly suit me
                Nope, no noticeable difference in noise/ anything. If your looking to save a few bucks though I'd say just skip the camber plates and instead put some new top mounts in.
                Also IMO you might as well do the GC kit route over a spring/ shock set up like you said. GC is a little more money of course but it's nice you'll have the adjustment, plus you have multiple options for spring rates.
                Side note, If you don't shorten the strut housings.. make sure at the very least you cut off the stock spring perchs and weld on the GC perches. I originally assembled everything without cutting the stock perches off but it didn't lower the car enough. Pics bellow from my old coupe on OEM top hats, non shortened strut housings, and GC spring perches.
                1991
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  +1, I learned quite a bit over the years since making this thread :D.
                  1991
                  • r-mm
                    • Jun 2018
                    • 203
                    This is an older thread but I am very happy I checked the fit of my Koni Orange STR.T inserts to my Sachs strut top mounts prior to taking the car apart.
                    Like the OP, the my Koni Orange (non adjustable) inserts use a 22mm top nut. A 22mm impact socket will not clear these Sachs brand strut mounts in which the opening is approx 31.5mm / 1.235"
                    https://www.fcpeuro.com/products/bmw...em-31331139452
                    Does anyone know if a 22mm socket will clear these Meyle strut mounts?
                    https://www.fcpeuro.com/products/bmw...-31331139452my
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Just an FYI...using an impact will void your warranty....and they do seem to know when you send it in for repair.
                      • RaabsIn513
                        • Jul 2016
                        • 36
                        i know this thread is old but i just found it. I had a similar situation (19mm vs 22mm special socket).
                        I have the Sachs strut mounts and one of them is defective. Did you notice the strut mount wobble before you put it back in the car? I made a video here:
                        Really disappointing to be making progress and have to stop and wait on a new strut mount.
                        • Vincenze
                          • Apr 2019
                          • 1044
                          This guy had the same problem with the Sachs mounts.
                          • KIRIEIW
                            • Dec 2012
                            • 3385
                            Did you maybe misplace a washer during re-assembly? Since you need to transfer over your old washer(s) to the new top mounts/ shocks its easy to misplace one.
                            1991
                            • RaabsIn513
                              • Jul 2016
                              • 36
                              I'm confident I didn't misplace any hardware. The Koni Orange struts are a larger diameter 22mm nut vs 19mm which seems to be the reason the one washer below the strut nut didn't fit
                              • RaabsIn513
                                • Jul 2016
                                • 36
                                I recall seeing this video prior to ordering my parts. I guess I was rolling the dice.
