Koni SA short rear shock
  • Von Soman
    • Dec 2018
    • 48
    Pelican list a short rear sport shock. What is the benefit to this shock over the standard length shock?
    Link: https://www.pelicanparts.com/catalog..._pg2.htm#item6
  • nrubenstein
    • 3148
    If you’re lowered, you get some extra travel.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Northern
      I like cupcakes & sh!tboxes
      • 5278
      IIRC the E30 specific rear Koni SA's are all the "compress to adjust" style, but you can get top adjustable Mustang shocks that are valved more aggressively, but only fit aftermarket rear shock mounts (12mm dia hole iirc, +2mm from whatever stock is.).
      Mustang shock Part numbers 8041-1186SPORT or 8041-1026SPORT. Same valving between these two, but -1186 has 50mm of bump stop at end of travel, whereas the -1026 is 5mm shorter overall and does not have a built in bump stop.
      2024 Edit: According to someone on the internet who emailed Koni, these aren't valved particularly stiff. They feel fine with 650lb rears, but apparently there are better options.
      Originally posted by priapism
      Originally posted by shameson
      • 2mAn
        Señior Mod
        • 20987
        I loved my Mustang Konis on the Aluminum Monster... jury's still out on the E30-spec SAs... I need to adjust them still and was a bit surprised when I saw what that required
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • glnr13
          • 1334
          +1 for the mustang konis
          • mwagner10702
            • Jun 2018
            • 49
            If you are lowered with spring rates between 400lbs - 900lbs and want to stick with Koni SA dampers I would go with the custom Ground Control rear damper. Part number 8041-1289SPGC. Use this along with their rear bump stop and you are set.
            These have the top adjustment for rebound and don't require getting under the car and removing the damper to adjust.
            1990 M3
            • dadsbmw
              • Oct 2014
              • 475
              Can you actually buy these by themselves? Searching that part number on google comes up with very few results
              2003 Z4 3.0 6-speed- Silver, 19's, daily driver
              1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
              1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
              • Northern
                • 5278
                When I attempted to buy some, they refused. 8041-1026SPORT is working nicely for me in the rear with 650lb springs.
                Front I have 8610-1437 Race in shortened housings, spacer underneath, with 450lb springs. (Although Roysneon runs the same front setup with iX konis and it feels great also)
                • hopeful
                  • Dec 2012
                  • 118
                  What modifications are required to fit these? Do you happen to know the compression/ rebound of these vs the 80 2522SP1?
                  • Northern
                    • 5278
                    The only required mod is to run a rear shock mount with 12mm hole. Since these are top-adjust, they have a thicker shaft to accommodate the adjustment mechanism.
                    I think most aftermarket RSMs can be bought as a 12mm variant.
                    I don't have any damping specs. I asked Koni years ago about the difference between 8041-1026 Sport and 8041-1186 Sport, I received the following but no damping specs:
                    The 8041-1026 Sport is shorter by 5mm in compressed length position, however it does not use a bump stop.
                    The 8041-1186 Sport does have a bump stop installed from the factory which makes contact with the shock body 50mm before full compression is reached.
                    The dampers are valved exactly the same.​
                    • digger
                      • Nov 2005
                      • 6188
                      anyone have any intel how the 8041 1289 SPGC compare to the mustangs 8041-1186 SPORT or 8041-1026 SPORT or TC Kline DA 8042-1134 TCK
                      i'm looking for something optimized for the street and 550lb/in so 1289 might be more suited to higher rates and track focused rather than pure street
                      • Dagamus(NM)
                        • 620
                        In addition to the answer to Digger’s question, curious to what rear Koni shock would be recommended for a late model vert on H&R sports. Not sure what the rate is on those though.
                        Gun control means using both hands
                        Sex, Drugs, Rock 'n roll. Pick two.
