How to bend front E30 struts?
  • romkasponka
    • Oct 2006
    • 8
    • JGood
      • Jan 2004
      • 7959
      are you serious?
      That's a great shot, a strut housing turned 60 degrees and redrilled, with the BMW safety and warranty sticker right below it.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • BM5W
        • May 2005
        • 84
        I also like the additional spacer/bolt! You had the car aligned with this "mod"?
        If it works, that is a damn cheap mod.
          • 34839
          it's actually not that uncommon to redrill the strut tower.. however it looks like you moved it the wrong way, you'd want to move it closer in to the center of the car for more negative camber. it's hard to tell at that angle though.
          • craz azn
            • 746
            ^^ I have to agree with Nando here.... looks like you just changed the 'caster' instead of changing the camber, because the mount is still relatively in the center of the tower still....well, maybe even looks a tad to the outside making it positive camber, LOL.... ( BTW I'm assuming this is a pic of the front left strut tower, and thats the fuse box to the right of the strut tower)
            Rippin' Proper | Youtube | Vimeo |
            • papajetta
              • Jun 2006
              • 155
              thats awesome, would have never thought of that, however i wouldn't try bemding it on my own, 1-3 degrees is pretty precise, next thing u know u could bend them to 10 degrees and f--- it all up
              • hopeful
                • Dec 2012
                • 117
                wow that looks butcherish. (the redrilled strut tower). However, funny enough thats standard procedure on some cars (done it myself on a Ford Taurus, thats what the procedure is for those cars when the Camber needs to be adjusted).
                I've been doing alignments for roughly only one year now and we've never pulled a strut. It could technically be done on these cars if the bend is below the damper inside the housing (not sure, never took it off).
                Most bending I've seen being done on cars at alignment shops usually is random pulling on bushings which is bizarre.
                • 603Racing
                  • Dec 2010
                  • 612
                  My guess would be that it was redrilled to reduce negative camber after lower springs were added.
                  I added camber plates to get back to -1.5 on my daily driver with H&R race springs. I want my tires to last more than 10k miles.
                  90 325i DD/Track
                  03 Durango 5.9
                  Originally posted by e30mpg
                  It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
