Koni NA - Big Thumbs Up!
  • Mtriple
    • 3139
    Originally posted by SuperDuper
    I discovered today that I have the exact same problem. One of the rears is leaking badly and I am not the original owner. I called Performance Shock Inc. and he is going to check with Koni and see if they can cross reference the shock. Koni's from GC have their own part number and are specific to GC. God knows I dont want to have to deal with GC if I dont have to. I'll update this post when I get an answer along with PSI's contact info.
    Good times...
    I should mention that I ended up going through GC and they were EXTREMELY helpful. Warrantied the bad one even though I was not the original customer.
    Thumbs up to GC's customer service.
    Originally posted by Simon S
    • BTP325ic
      • Apr 2009
      • 700
      Originally posted by nando
      do you ever post anything worthwhile?
      It's a sticky because there is contact information that you could use to get your shocks rebuilt.
      lol;)
      • hotballs
        • 1155
        Originally posted by Mike B.
        I had a leaky rear Koni SA shock with my Ground Control setup, so I called Koni NA to send both rears to be revalved for my spring rate.
        Great experience! Repaired the leaky shock, revalved for 1000lb springs and repainted the bodies - they look brand new. All in a 2-week turn-around time. $234 for the whole deal.
        What front rate are you running? Somewhere around 800?
        • Moto-Mucci
          • 2058
          Anyone have the part# for those bump stops? Are they stock? My car never had them.
          • drumad
            • Aug 2009
            • 1700
            realoem.com? come on dude.
            2008 335i - n54b30
            1991 318i - m52b28
            1994 fzj80 - LAND CRUSHER
            • Moto-Mucci
              • 2058
              I asked if they were stock DUDE.
              • Jean
                • 18228
                I just run stock E30M3 sways, that can be disconnected depending on the track. I am a proponant of less bar and more spring to help with lifting the inside rear tire.
                I don't think 1000lbs is too high as my lap times indicate the opposite. Heck, the Grp. N factory dry setup is 1142lbs front and 1368 rear and I've also seen an 800/1143 Grp. N setup as well.
                Fred - Keep in mind that shock valving has a HUGE effect on ride quality and harshness, much more so than spring rates.
                Teaguer - These were installed on the car when I purchased it last February, and I had no original documentation for the shocks. I think they may have been 2-3 years old. I don't think you will have any issue with what you have to be rebuilt. My contact was:
                Paul McLaughlin
                Koni Shock Absorbers
                ITT Corporation
                Racing Technical Sales Rep.
                1961A International Way
                Hebron, Ky. 41048
                800-922-2616x324
                Stereo - The shocks were fully rebuilt (along with the revalve) as one was leaking oil like a sieve.
                Saved for later calling.
                • drumad
                  • Aug 2009
                  • 1700
                  so is this not a question? and no, not stock iirc. so my realoem.com response is not valid either.
                  edit..the more I stare I keep thinking theyre front ones turned upside down but they're a different shape.
                  2008 335i - n54b30
                  1991 318i - m52b28
                  • bear
                    • Jun 2010
                    • 191
                    speedthane shock bumpers, dooooood! used em alot in my rockcrawler days
                    91 325ic
                    85 528e
                    92 325i
                    86 535i gone
                    92 325is gone
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      Did I miss something? Don't ALL KONIS shocks come with a lifetime warranty? Why did you have to pay?
                      1997 Artic Silver M3
                      CES GT4094r 651hp/615tq @ 24 psi
                      • M-technik-3
                        • 18946
                        Because he had it re-valved not a simple exchange for an off the shelf unit.
                        • einstein57
                          • Jun 2007
                          • 10780
                          Inflation sucks. They quoted me $165 per strut plus parts up to an additional $100 per strut. $330-530 ain't worth it.
                          www.gecoils.com
                            • 34844
                            yeah, definitely not. that's the same cost as new ones.
                            • ROLLingKING
                              • Apr 2011
                              • 1169
                              Originally posted by robspeed325i
                              Bilstein will also rebuild and revalve any shock to any spec. I think rebuild is $60 per and respec is a few more $$ since all they do is change valve body during the rebuild.
                              you just saved me about $600 bucks. thank you
                              m20 is plenty. im simply a drifter.
                              build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                              • yeaseth
                                • Jul 2011
                                • 302
                                Bilstien quoted me 125 a shock, and that was with the stock revalving :( So I ended up just getting a whole GC setup which is way more but worth it!
                                benvideoproductions.com
                                http://www.youtube.com/watch?v=617yNrOrRfo&
