delete
  • nugentnsb
    • Jul 2011
    • 444
    #31
    He won't reply to my emails, and should'nt there be bbs stamps on them? i don't see anything on the faces.
      • 34844
      #32
      they are usually in the spot that he filled/drilled. they probably got ground off.
      • nugentnsb
        • Jul 2011
        • 444
        #33
        The reason I asked if it was my fault for using stock lugs, was because after I emailed him about what happened, he told me that i needed "tuner style" lugs. But seen in the previous post, he had a wheel with stock lugs on them.
        • IRON-E
          • 16548
          #34
          Is it just 1 wheel that you test fitted? The picture Robrez posted, doesn't look like the same wheel you have.
          My conclusion to this issue is, that because the holes where set up for tuner lugs, you stretched the CB by torquing them down in all 4 corners. The material will stress, regardless of what wheels or bolt pattern they were originally. (example= if these would have been 5x120 with tuner lug holes, and you used lug bolts, like you mentioned., the same thing would have happened)
          I 'mnot deffending the seller by any means but, this does look like user error.
          @IRON-E30 aka Edwin:D
          • nugentnsb
            • Jul 2011
            • 444
            #35
            But if the stock e30 bolt size is M12x1.5 bolt thread, and the tuner lug size was M12x1.5 bolt thread, wouldn't it ended up the same way??? regardless
            • LJ851
              • 7919
              #36
              No, tuner lugs are much smaller in OD above the threads to fit down small holes. It is their whole point.
              Lorin
              The M30 is God's engine.
              • willworkfore30s
                • Aug 2011
                • 1090
                #37
                I would have expected a cast wheel to crack rather than warp like that. These are cast wheels right?
                • SmokeE30
                  • 1730
                  #38
                  Originally posted by FLG
                  As I said previous is there a plastic or metal hubcentric ring in there that's actually the messed up part? It's hard to tell from the pic
                  Sent from my Galaxy Nexus using Tapatalk 2
                  This was my thought, it appears that the ring in the centerbore is the only part that's deformed, if it is removable you may get lucky and be able to replace it
                  Shawn @ Bimmerbuddies
                  Bimmerbuddies LLC
                  717-388-1256
                  2971a Roundtop Rd, Middletown PA 17057
                  bimmerbuddiesllc@gmail.com
                  • kalib0y
                    • Dec 2004
                    • 3620
                    #39
                    the OEM heads on the stock lug bolts are much larger in diameter than tuner nuts. Did you notice that the stock bolts tried to stop at the face rather then go through the face to properly seat IN the lug hole?
                    These wheels are done. Sorry to say that
                    95 7.1L 16V E36 M3
                    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                    LIKE my Facebook Page! CLICK HERE
                    • nugentnsb
                      • Jul 2011
                      • 444
                      #40
                      Nope, he never told me I needed tuner lugs until after I messed them up. I told him before I bought them I needed them for an E30, and thought since the wheels were newly filled/drilled and it was suppose to be like that.
                      • glnr13
                        • 1334
                        #41
                        Originally posted by robrez
                        it kinda looks like they're 4x110's that have been torqued down on a 4x100.
                        when you were torquing the lugs down did it feel smooth or was it quite a bit of effort to get them all down? also, a bit of advice, it's always safer to torque lugs with a torque wrench. breaker bars are for busting them loose.
                        • efficient
                          • Feb 2012
                          • 3312
                          #42
                          should have bought esm 002, would have been much cheaper.
                          • IRON-E
                            • 16548
                            #43
                            Mmmmm, NO.
                            • MJCRO
                              • Apr 2012
                              • 597
                              #44
                              Originally posted by iron-e
                              mmmmm, no.
                              LOL. Fail.
                              • nugentnsb
                                • Jul 2011
                                • 444
                                #45
                                holy!
