delete
Nothing wrong with paying $2.5k for redrilled wheels if its done right.
And whoever asked. These are forged wheels.
I can't see this happening due to tightening the lugs wrong. I could be wrong, but it seems to me that if the cb was proper, tightening the lugs like this would not warp them, the cb would help to keep them round.
I'm 95% certain this is not your fault. I think this is from a poor redrill.
For anyone reading, please do not be afraid to get your wheels redrilled. Just make sure you get it done properly by someone who knows what there doing. (Me)
Edit: I take that back, it looks like you did do this by tightening the OEM lugs down. But how, I'm not sure. That area should not be that soft, I think it's a good thing that you found this before they were drivin on.
These require tuner bolts, that should have been specified.Last edited by formula driver; 07-13-2013, 11:26 AM.
whoever said 'not 4x100' is probably right.
looks like the wheel's drilled holes were wider (black circles) than the stock 4x100 (blue circles), so when you put the lugs in (blue dot) they centered on the stock 4x100 and forced the wheels lug openings inward causing the sides of the hub opening to collapse inward (red)
the OP should measure the lug pattern.
They were filled and then drilled so unless they were tempered again they would not have the same strength as before.Comment
NOW it makes sense. I think it was just a poor attempt at 4x100. I can't think of anything else that would cause it to deform like that, maybe they were drilled 4x108 for some reason?whoever said 'not 4x100' is probably right.
the OP should measure the lug pattern.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
I think its more like 4x98 or something like that.whoever said 'not 4x100' is probably right.
I say this because he drilled them for tuner lugs, which is done to avoid cutting into the center of the wheel that the hex cap screws into, yet he still cut some of that area out.
That area looks the same on my redrills, but this is because I drill my faces to use factory lug bolts which are larger than tuner lugs.
