15s or 16s
  • InflatableWolf
    • Oct 2017
    • 13
    15s or 16s
    So in the future, I plan on doing the Bilstein shock and H&R Sport swap on my 318IS, but I'm on the fence between 15" or 16" wheels.
    I want to know which would be better and if I need any kind of extras to go with the rims like spacers or certain tires.
  • TURBOX
    • Mar 2016
    • 138
    i like the look of 16's
    post a poll n sum pics
    [1991, E-30 325i, 5-Speed, M20, Brillantrot] [1998, B5 Passat 1.8t] [2007, R6 Yamaha] [2011, Tundra 5.7]
    • Mike36
      • 1079
      16s!
      • Metallated
        • Dec 2016
        • 1073
        15s are more available and better looking imo
        Plus I've heard 16" tires are a pain to source and expensive when you can...
        • InflatableWolf
          • Oct 2017
          • 13
          So 15s would be easiest, would I need to do anything to the suspension or hubs to fit them with the 1" drop? Or just shoot for lo-pro tires and call it good?
          • Holland
            • Nov 2008
            • 7212
            Check the wheel and tire threads, there are loads of setups in the 15 and 16 inch posts. Short answer is yes though, with the correct offset and tire size you should have no issues.
            Originally posted by DEV0 E30
            • varg
              Florida Turbo Man
              • May 2014
              • 3404
              Tire choice is the most important factor if you like driving. If you're looking to hard park or scrape it's all about the looks and you won't mind riding on low traction stuff.
              Scope out the availability of good tires before you make your choice.
              IG @turbovarg
              '91 318is, M20 turbo
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5555
                With that drop, I'd look at 205/50/16s Or 225/50/16s.
                There are plenty of options, both in performance and a higher tread wear
                • InflatableWolf
                  • Oct 2017
                  • 13
                  I was going to try for a good balance of looks and function. Still going to be a daily, but I love the look of the lowered 318s.
                  The stock 14s I'm running now look too small even now on the car and I've been seeing quite a few 16s. My main concern was, like I said above, I want looks and function, and I thought maybe the 16s would be too big with the ride drop
                  • Zeemz
                    • 485
                    205/50/16s are the proper size, but 225/50/16s are a little taller. 225/45/16 are the proper 225 size, just less tires to choose from.
                    14s vs 15s vs 16s isn't a problem for ride height. What impacts if you can lower on different sizes is the width of the wheel and the offset. If you have the proper offset and width and an appropriate tire size there is no need to roll your fenders or stretch your tires. The more aggressive the offset or wider wheel then you get into having to roll and stretch tires to avoid rubbing.
                    Check out these threads, offsets and tire widths still hurt my head, but I learned a lot reading through these threads and about how I wanted to setup my suspension and wheels/tires
                    The suspension setup/ride height thread - https://www.r3vlimited.com/board/sho...=52154&page=36
                    https://www.r3vlimited.com/board/sho...83125&page=633
                    E30s on 16s - post yours
                    Here is my post from the E30 on 16s thread:
                    Wheel/Tire/Suspension:
                    BBS RS003s - 16x7 ET25 - Nogaro Centers with brushed lips & hexes
                    Dunlop Direzza ZII Star Specs 225/45R16s
                    H&R Sports, Bilstein Sports, E90 Drop Hats, M3 Offset CABs
                    1989 325is Lachssilber - Sold
                    1990 325is Sterlingsilber - Current Project
                    September 2018 Car of the Month: Zeemz
                    Youtube Track & Autocross Videos
                    • InflatableWolf
                      • Oct 2017
                      • 13
                      So after much thought and looking, I'm thinking I'll go with 16" wheels, and I've been looking at Ruff Racing, XXR wheels, and CCW.
                      As for actually getting a set, money is the next question but I'll leave that to my bank LOL
