This is a sticky topic.
  • E30SPDFRK
    • 5693
    #2926
    Originally posted by Danny
    Any problem using BfGoodrich tires from 2005 production?
    I don't know where Jay has been, but I wouldn't want to use them. Tires have a shelf life of 4-6 years. Even if they havent been used, the rubber still breaks down inside them and acts just like a dry rotted tire. I've seen a 5 year old tire with 500 miles on it seperate before.
    Byron
    Leichtbau
    • RainierHooker
      • Jul 2009
      • 2026
      #2927
      My qustion still stands. I wanna order rubber this week...
      15x7 ET18 on a high-arched early model with H&R Sports and Billstein Sports. I'm planning on using 205/55R15 tires on them. These should be fine without any fender rolling or other craziness right?
      In addition, anyone think I could get 225/50s on there without rubbing?
      1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
      • TheBANKe30
        • Nov 2009
        • 103
        #2928
        hello i have a 4x100 conversion adapter for 114.3 rims my adapters are two wide and hit the brake caliper. is there a solution for this like customizing the brakes or oh fuck i bought the wrong adapters
        95' e36 325i manual 102k - dead and parted
        87' e30 325i manual m50 102k - alive again
        89' e30 325i coupe manual 162k - acquired june. 2009
        sold dec. 2009
        88' e30 325ix coupe manual 182k
        " Everything happens in series of three "
        e30 all day
        • akorcovelos
          • Dec 2006
          • 1149
          #2929
          Originally posted by Mystikal
          Yeah that's his name here too.
          You can't run both the 8mm and 5mm together because there will be no hub for the wheel to sit on. You can get the wheels on without spacers in the rear and run 245/35/16 Toyos, that would actually be a pretty good setup. For the fronts, you will need at least 10mm to clear the struts. So I'd probably go with the 16mm up front, roll the fenders flat, and slap on some 225/40/16 Toyos to match the rear.
          hey there, I need a little advice from you guys again. I just got word that TOYO has stopped producing the 225/40/16, and possibly the 245/35/16, so with my setup is there a more common tire size I can run? I have the front fenders rolled flat and slightly pulled.
          edit: so you don't have to go searching, I'm running 16x8.5 k1s with et27 offset.
          2012 MCSCC/NSSCC CP class champ
          HSAX Instructor
          • z31maniac
            • 17566
            #2930
            215/40/16
            www.gutenparts.com
            • akorcovelos
              • Dec 2006
              • 1149
              #2931
              I would rather not go to a 215. With 215s up front and 245s in back handling will suffer quite a bit...I was hoping to her 225/45/16 would be ok, or even 235 up front with a smaller spacer.
              HSAX Instructor
              • z31maniac
                • 17566
                #2932
                225/45/16 is stock OD.
                I didn't suggest that since you were mentioning 225/40s and 245/35
                www.gutenparts.com
                • akorcovelos
                  • Dec 2006
                  • 1149
                  #2933
                  would the 225/45/16 match up to the 245/35/16s I already have in the rear, or will it look off? I'm kinda stuck since I already bought the 245/35s.
                  If I didn't run the 245/35s would a more common 245 fit in the rear with the 225/45s up front?
                  HSAX Instructor
                  • Kolia
                    • Jan 2009
                    • 8
                    #2934
                    I'm trying to figure out if these would fit ?
                    Hankook Ventus R-s3 in 225/45R15 on 15x8 rims with +20mm offset.
                    Back spacing is 5.31in
                    On a 318is with Eibach Race with Bilstein strut.
                    Thanks
                    • blefevre
                      • Dec 2008
                      • 4287
                      #2935
                      I can't find a definitive answer to this.
                      I have 14in. basket weaves with 205 wide tires - BFG Traction T/A.
                      Can I fit 15mm H&R spacers in the REAR without rubbing? I will be lowering the car on H&R sports very soon, will it rub then?
                      - E30, DSM, Golf R, Mazda 3 Skyactiv
                      • BustaRhymes325i
                        Gaping Anus OG
                        • Aug 2009
                        • 243
                        #2936
                        Ok crazy fitiment question here:
                        I have 2 Merc Benz AMG wheels, size 18x9, ET23, 5x112. If I use a 4x100 to 5x112 adapter (dangerous, I know) which is 20mm thick, will these wheels fit on the rear?
                        I am dropped on Eibach sports and Bilsteins. If so, what type of tire sizes am I looking at? Car is a 1989 if that helps.
                        Thanx!
                        • maniacmatt
                          • Feb 2007
                          • 483
                          #2937
                          Okay I have one. The car is a 90 325is with GC coils, front camber/casterplates and IE weld in rear camber toe kit. Fenders and quarters are not rolled.
                          The wheels I want to fit are:
                          Front
                          7.5x16 et27 I currently run a 3mm spacer to clear my Massive street kit, not sure if I would need it with these wheels.
                          Rear
                          9x16 et21
                          What tire sizes am I looking at running to make these fit? Will I need spacers front or rear?
                          • e30bri
                            • Apr 2009
                            • 24
                            #2938
                            Fitment Question:
                            88 325is IE st3 springs
                            15x8 et20
                            Tire Hankook rs3 225/45/15
                            THANKS!!!
                            • akorcovelos
                              • Dec 2006
                              • 1149
                              #2939
                              little update, I ended up having to go with 215/40/16 up front, which happens to be exact same OD as the 245/35s in back. Only problems will be more drastic stagger and stretching 215s on an 8.5" wheel.
                              I'm still looking for a better fitment option for my next set of tires if anyone has any suggestions.
                              HSAX Instructor
                              • stegosaurus
                                • 367
                                #2940
                                I have some Kopi Alpina reps 17x7.5 ET20 which are stretching 215/40/R17 tires. I bought them needing new tires, I'm hoping I can do 225/40/R17 because I really don't like stretch.
                                No fender pulls or rolls, car is a little lower than usual, but not much. Doesn't rub anything as is. Might have some clearance issues in the front I'm guessing with that plastic shroud, but I could just take it off.
                                If bigger tires won't happen without rolls, pulls, spacers, then I guess I'll stick with the 215s.
                                What do you guys think?
