? for the master 17x7 37et what will i need to make them fit? and what tires can I run. Eibach springs Bilstein sports thanks in advance
This is a sticky topic.
http://raceskids.com/ -
with that set up will I have to roll the lips?Custom Made Skid Plates For Sale.
http://raceskids.com/Comment
got a problem,
specs:
-(4) Borbet Type A 16x9's ET15
-5mm spacers in the front, none in the rear (for now)
-2 hubcentering rings on the front wheels ( i know i need 4, working on it)
Problem:
The car shakes VIOLENTLY from about 40-50mph.
As i was at work tonight i was thinking... with the spacer up front the Hub Centric ring doesnt even fit itself around the hub.
How do i fix this? Could it be as simple as a balance? im still worried about the spacer/ring situation though
Please help me out, TIA.
You may need different rings, as there are Borbet 16x9 guys running around with 5mm spacers. Perhaps their hubcentric rings are less tapered. It could also be a balance issue, and I'll scratch out car issues since I'm assuming it didn't do this with other wheels at all.
JayComment
Just wanted to make sure this would fit without fending rolling or rubbing:
slipstream 16x8 with falken 225/45/16's on an 88 cabrio. I've searched and keep coming up with different comments on whether fender rolling is necessary. Oh yeah, H&R sports with bilstein sports.
Thanks, Doug
If you get 205/50/16's, there shouldn't be an issue.
JayComment
Whatup Jay. Got another question.
17mm offset rear.
19mm offset front.
Currently 22mm all around.
Will I need longer lug nuts? And for clarification, whats the length of the stock ones?
Planning on getting 57.1mm centerbore spacers instead of those universal ones.
And Doug, its always beneficial to do a proper fender rolling with the right tool, its worth it, I know my fenders liked it!
You will need longer bolts for 5mm, I can't recall at the moment what the stock length is (thinking 45mm). But, I just plain tell people not to run 5mm anyways.
JayComment
5mm in the rear, 3mm in the front.Reminiscing...Comment
The only motivation is to have them sit closer to the fenders, more flush. Also trying to fix wheelshake at the same time.Reminiscing...Comment
cheerssigpic340hp V8 e30 FINISHED!!!!!
Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
NEW One on the track :)
http://www.youtube.com/watch?v=K-AX5SzSLnk
Cleaning up some 911s and Jap turbos
http://www.youtube.com/watch?v=Ad79wsLdle4Comment
tire size
Jay,
Thanks for setting me straight. Appreciate the help!
DougComment
