This is a sticky topic.
  • Yakinho
    • Feb 2007
    • 650
    #286
    Ok. Will 17x7.5 with an offset of 40mm fit without anything done? or will I need to roll the fenders, fit spacers, etc...?
    • drifty340i
      • Oct 2004
      • 1076
      #287
      Originally posted by Mystikal
      Well don't do any kind of spacing until you install and adjust the bushings. Depending on the camber you want, you can either end up with a car that rubs the fender without spacers (i.e. 0 camber), or one that can run 15mm spacers (i.e. -4).
      Jay
      Ok good call and that makes sence! i want 0 camber on the back so i can have as much tire on the road as possible because ill need it with the v8.
      Your the man by the way lol cheers again!
      Riley
      sigpic340hp V8 e30 FINISHED!!!!!
      Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
      NEW One on the track :)
      http://www.youtube.com/watch?v=K-AX5SzSLnk
      Cleaning up some 911s and Jap turbos
      http://www.youtube.com/watch?v=Ad79wsLdle4
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #288
        Originally posted by PiercedE30
        Ok, here's a quick one.
        I've got a set of 17x9 et 8 wheels sitting at my shop. Two of the wheels have 245/40's on them. I put them on the front, look great, suspension still needs to settle some, etc. Is it even possible to fit 245/40's in the rear without any work on late model rear arches? I'm guessing not without any flaring. The 245's even have a little bit of a stretch to them since you would need like a 265 or a 255 for the tire to be square shouldered.
        Unless you're stretching on 215's or running massive camber, those wheels just won't work with stock bodywork.
        Jay
        • Mystikal
          • 9602
          #289
          15mm spacers, won't need to roll the fenders with 215/40/17 tires (good choice).
          Jay
          • Yakinho
            • Feb 2007
            • 650
            #290
            Thanks a lot man:D
            • TOAST
              • Jan 2006
              • 316
              #291
              great thread here, i think i read every page
              any thoughts on rubber size brand & model for some 15x6 kopi alpina replicas?
              TIA
              • golde30
                • 11464
                #292
                from vorschlag: 57mm stud good up to 8mm spacer safely. anything more than that they suggest the 80mm stud.
                now, heresay on the forums is 60mm stud kit w/ 12mm will work. but i make no claims or gaurantees.
                IG: @Baye30
                • Mystikal
                  • 9602
                  #293
                  TIA
                  They're 15x6.5", aren't they?
                  205/55/15 would be the correct aspect ratio. 205/50/15 would probably look better though. For tire commendations you'd have to make another thread, there's a lot of discussion needed (your needs, etc).
                  Jay
                  • ejnight
                    • Apr 2007
                    • 3488
                    #294
                    17x7 37et what will i need to make them fit? and what tires can I run. thanks in advance
                    http://raceskids.com/
                    • BMWE34M5
                      • May 2004
                      • 4406
                      #295
                      Correct-they are 15" x 6.5".
                      205/50/15 will be the better choice.
                      Jay
                      Mel Abrahams
                      Abrahams Motorsport
                      www.abrahamsmotorsport.com
                      PayPal to:
                      order@abrahamsmotorsport.com
                      Phone:727-992-0288
                      Fax:727-868-6373
                      • 32.5i
                        • Sep 2005
                        • 1336
                        #296
                        got a problem,
                        specs:
                        -(4) Borbet Type A 16x9's ET15
                        -5mm spacers in the front, none in the rear (for now)
                        -2 hubcentering rings on the front wheels ( i know i need 4, working on it)
                        Problem:
                        The car shakes VIOLENTLY from about 40-50mph.
                        As i was at work tonight i was thinking... with the spacer up front the Hub Centric ring doesnt even fit itself around the hub.
                        How do i fix this? Could it be as simple as a balance? im still worried about the spacer/ring situation though
                        Please help me out, TIA.
                        • SoCal Life
                          • Jun 2006
                          • 323
                          #297
                          Originally posted by 32.5i
                          got a problem,
                          specs:
                          Problem:
                          You could of just called me, oh wait, you did. Sorry, bad reception in Torrance.
                          Anyway- I think it's cause those spacers he gave you where not hubcentric. But they are only 5mm thick, so it really shouldn't make a diff, your hubcentric ring should still be able to reach the hub to properly center it.
                          You tires are bad enough that it might just be the tires. You'd be surprised with how much it makes a difference. Especially when you're talking about 215/40's on 9" wide wheels.
                          I'll swing by and check it out when I get home tomorrow.
                          e30 325is - e30 M3 [FOR SALE] - Audi S4 - '78 F-250 .....clicky clicky
                          • fairhope30
                            • 25
                            #298
                            Just wanted to make sure this would fit without fending rolling or rubbing:
                            slipstream 16x8 with falken 225/45/16's on an 88 cabrio. I've searched and keep coming up with different comments on whether fender rolling is necessary. Oh yeah, H&R sports with bilstein sports.
                            Thanks, Doug
                            • M42Technik
                              • 9781
                              #299
                              Whatup Jay. Got another question.
                              17mm offset rear.
                              19mm offset front.
                              Currently 22mm all around.
                              Will I need longer lug nuts? And for clarification, whats the length of the stock ones?
                              Planning on getting 57.1mm centerbore spacers instead of those universal ones.
                              And Doug, its always beneficial to do a proper fender rolling with the right tool, its worth it, I know my fenders liked it!
                              Reminiscing...
                              • 32.5i
                                • Sep 2005
                                • 1336
                                #300
                                Thanks, Doug
                                whats the offset on these wheels? I know Dom has them and i dont think his fenders are rolled.
