This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #331
    Originally posted by whiltebeitel
    Ok. Can 205/50/15 RA-1's fit on a 15x8?
    Yes.
    Jay
    • Van Westervelt
      • 9365
      #332
      Originally posted by Mystikal
      What's the source on the info for M3 hubs being 5mm further out? I've never heard of that, and know of E30 5-lug guys running wheel setups identical in fitment to 4-lug.
      In any case, ET11 16x8 is aggressive as hell.
      Jay
      I thought you were the expert? wtf?
      • Mystikal
        • 9602
        #333
        And who said I wasn't? I'm asking you who told you that information, because I have never heard anything like that.
        Jay
        • Tarn
          • Sep 2006
          • 212
          #334
          Hi, im running GC setup and i would like to know if any of the following configurations will work without rubbing or rolling.
          15x7 offset 35, tire 205/50
          15x7.5 offset 20, tire 205/50
          I see a trend in tire brand what are your thoughts on Nokian H's.
          Thanks
          • whiltebeitel
            • Apr 2007
            • 2098
            #335
            I ran a 15x7 195/50/15 et38, and it was on the verge of rubbing under the most extreme AX conditions, with more skilled drivers showing me how to wring the car out. The 205 shouln't be an issue.
            '89 325i track sloot
            '01 530i daily
            -Enginerd
            • BMWE34M5
              • May 2004
              • 4406
              #336
              You will need spacers with the 35mm offset wheels.
              Thanks
              Mel Abrahams
              Abrahams Motorsport
              www.abrahamsmotorsport.com
              PayPal to:
              order@abrahamsmotorsport.com
              Phone:727-992-0288
              Fax:727-868-6373
              • Mystikal
                • 9602
                #337
                Thanks
                The fronts will either contact the strut housings or be too close for safety. Need 15mm hubcentric spacers. The rear is fine as is.
                The Nokian H isn't available in that size, however the V is. I don't have any data for that tire.
                Jay
                • Tarn
                  • Sep 2006
                  • 212
                  #338
                  Jay
                  Thanks Jay.
                  • stumpsbmwm3
                    • Mar 2007
                    • 51
                    #339
                    Please give info on this fit
                    Greetings,
                    I have four ADR 24's.
                    ET-40
                    17 x 7
                    They currently have 205/40zr/17's
                    What spacer, if any, are required to fit a stock 1990 325i?
                    Thanks
                    • BMWE34M5
                      • May 2004
                      • 4406
                      #340
                      Ideally you need a 20 mm spacer - that's over 3/4 inches!
                      40 mm is the wrong offset for an E30.
                      Did they come off a front wheel drive Japanese car?
                      Make sure you have a 4 x 100 bolt pattern.
                      Originally posted by stumpsbmwm3
                      Greetings,
                      ET-40
                      17 x 7
                      Thanks
                      Mel Abrahams
                      Abrahams Motorsport
                      PayPal to:
                      Phone:727-992-0288
                      Fax:727-868-6373
                      • stumpsbmwm3
                        • Mar 2007
                        • 51
                        #341
                        Originally posted by BMWE34M5
                        Ideally you need a 20 mm spacer - that's about one and a half inches!
                        Yes they did (Honda). They are, however, 4 x 100's.
                        • stumpsbmwm3
                          • Mar 2007
                          • 51
                          #342
                          Also, please say no, do I have to deal with rolling fenders?
                          • 2002maniac
                            • 4260
                            #343
                            not quite. it's actually just over 3/4"
                            • BMWE34M5
                              • May 2004
                              • 4406
                              #344
                              You're going to have the opposite problem - they're going to touch your struts.
                              Best is to sell them and get wheels with the correct offset.
                              I would not recommend such a large spacer.
                              Mel Abrahams
                              Abrahams Motorsport
                              PayPal to:
                              Phone:727-992-0288
                              Fax:727-868-6373
                              • BMWE34M5
                                • May 2004
                                • 4406
                                #345
                                You're right - I stand to be corrected.
                                That's still quite a hefty width.
                                Mel Abrahams
                                Abrahams Motorsport
                                PayPal to:
                                Phone:727-992-0288
                                Fax:727-868-6373
