	This is a sticky topic.
 Ha, stop looking at E9x spec wheels. They'll look good though, and no spacers needed.
 Those 18s are tough fitments. Looking at lots of stretch and rolled guards, likely pulled rears. 225s will be about the limit, or find some rare 235/35s. Either way it'll be work but it'd look sick.
 The 17s are boring, but you could run huge rubber (245/40 front, 255/40 rear). Would just need a minor rear roll.Comment
 Even with 18mm adapters, 205/45s will require a fender roll in the back.I just picked up some C4 corvette wheels. 16x8.5" 32mm and I'm going to be using 18mm or 20mm adapters. What's the meatiest tire I could run without fender mods, for 18mm or 20mm adapters? Thanks so much.
 I'm not too low at all, there's a pretty good gap up front, less of a gap in back. 1991 E30 318is for reference.Comment
 Hubs are the same, wheels will work fine without spacers. They will be VERY sunken into the fenders though, you'll see.Comment
 Originally posted by e30elose the old man bmwcca badge.Comment
 I got the ones from ebay, I read on here that people just use the stock bolts and dont even need hubcentric rings...where do i buy these? any tire place? 57.1? right?
 thanks jayOriginally posted by e30elose the old man bmwcca badge.Comment
 This is just me being safe and double checking my search results. a 16x9 et15 will fit in the back of my 89 with nicely stretched 215/40's. even with a 2" drop? looking into getting ESM 008's stagered. any tire brand recomendations? i imagine some behave better than others when stretched.Comment
 Cheers mate, I agree on the 17's front, but they do look sexy!Ha, stop looking at E9x spec wheels. They'll look good though, and no spacers needed.
 18's all day on an E36 i reckon. 19's if you're brave.
 RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
 Okay, sorry but, what if I were to go H&R Race instead and change nothing else?Those 912s will work without fender rolling on your early arches. If it was another tire, it wouldn't work (those are only 9.0" wide, while others are 9.2-9.3") and if it was a late model, it wouldn't work. Sounds like a perfect match to me.1987 325is
 H&R Sport
 Bilstein Sports
 15mm Drop hats
 15x7 Rota Slips spaced from ET40 to ET20
 Question is...
 I want to run 225 50 15's(Falken Ziex 912 if brand matters)
 Will I have rubbing issues without rolling the fenders?
 Got a better tire size suggestion for the best looking wheel arch fill?
 Thanks!
 Mikey
 Would the drophats then be overkill?
 Would the fenders then need to be rolled?
 Any suggestions?
 Thanks in advance.
 Equal rights should be all or nothing, not picked and chosen based on what's convenient for ones personal agenda.
