What do you mean "flat rear fender lips"? like pulled or do you mean the lip on the lip? haha, the flat lip inside the arch, you mean flatten that against the actual arch? I'm confusing myself trying to explain it.
Forgot to add the style 19s are being redrilled to 4x100, i am not running a 5 lug swap. (if that makes the offset different)
Flat meaning the inner lip rolled up flat against the inside of the quarter panel. So, yes.
Redrilling helps with clearance, as the M3 hubs push the wheels outward slightly (wider track).
Thinking of upping my current 215/40 Pzero Nerros on the Kopis (17x7.5, et20) to a 215/45 Continental Extreme DWs for a bit more sidewall compliance. Any issues? I don't currently rub, but shit is pretty low...
Great tire model, but you will most likely rub with that size. Go with a 205/45 to get a little more compliance (you'll lose some grip of course).
Question about fitment. I can't find anything on it. I have a 91 325is. I want to get these:
rear 17x9 et30
front 17x8 et35
Will the work. Is there any modifications I would need to make. Also what tire size should I run if they will work. I would like to car to be low if possible.
Should I go 225 and if I did would I need any roll on the fenders?
Should I just do 205 to avoid any trouble? (It's just a street car anyways for now)
How much does this all change if I go Vogtland Springs instead of HR?
Thanks!
Even with 205s it will be close without fender rolling. That is a very aggressive wheel. Springs are irrelevant, mostly.
rear 17x9 et30
front 17x8 et35
Thanks,
Jason
You will need 10mm spacers, front and rear. For tires go with 205/40 and 225/35 ideally, or if the 225/35 is too scarce/pricey just run a 215/40 in the rear.
i have a sedan and just picked up wheels 16x8 et0 and tires on them are 205 40 16 test fit them and looks way too small.
any reccomendations on which tires to run 215 45 16? maybe 225 50 16 rear
not really a fan of stretching
r3v does not fuck around. First you get banned, then they shoot you
im interested in the new esm 002's
new sizes available are
17x8.5 et 15 and 17x10 et 20
obviously id need to roll, but would i need to default
to the agressive roll + what tire sizes should i go wiTh
Car is lowered 1.5"
