Ok I have tried figuring this out using guides but cant seem to get it right. I found a set of 15x8 gottis with 5x144.3 -13 et. I was thinking of filling and re-drilling or running adapters. Would it even be possible to run adapters? Btw this is on an early body car with rolled and pulled arches
This is a sticky topic.
Originally posted by duckBoy View PostI planning on running style 5s with 225/45R16 all the way around.
What else would I need to get/do besides hubcentric rings and maybe a front roll?
Do i need spacers?1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSD
Originally posted by mkcman17 View PostI'm in the process of doing the same, picked up my wheels yesterday. Are you redrilling or are you 5lug? If you're 4 lug we have a lot to talk about haha
Originally posted by mops View PostQuestion to experts.
I got this setup (as below in the quote).
I noticed a bad handling characteristics. Basically when I'm breaking hard from high speeds, the car is wandering, quite abruptly, therefore constant steering input is required while breaking to keep it straight. It just doesn't feel very safe or nice TBH.
I suspect this is because front wheels centerline is now ~20mm outside (as opposed to stock bottlecaps), and because these tires have much more grip when breaking, I suspect this exerts significantly larger forces on the control arm bushing (I use urethane bushes), and in effect front wheel geometry is forced into toe-out situation under heavy breaking causing the described characteristics ?
Could anybody comment on my theory ? or perhaps confirm that with similar setup are getting similar behavior ? any other theories or perhaps hints on what to try to fix this issue ? I was thinking maybe solid buschings - not 100% solid but on which the movement is very restricted ?
Thanks,
Mops.
Originally posted by Shangsta View PostOk I have tried figuring this out using guides but cant seem to get it right. I found a set of 15x8 gottis with 5x144.3 -13 et. I was thinking of filling and re-drilling or running adapters. Would it even be possible to run adapters? Btw this is on an early body car with rolled and pulled arches
