This is a sticky topic.
    Originally posted by rav320uk View Post
    What would be needed to fit
    RS 003's origional ET on a 7j wheel of 25.
    These have been built out to 9.5j rears and 8.5j fronts.
    Rav
    16x8.5 +5 and 16x9.5 -7? Heavily pulled rear arches, lots of front AND rear camber, and the smallest tires you can stretch on (205/40 and 215/40 is good).
      Originally posted by LancE30 View Post
      i saw e30robs spacers andit sparked my curosity for these.
      Those are 15s. If you really want to run them you can with Rob's adapters, but there are plenty of 4x100 15" weaves that look exactly the same.
        Originally posted by Mystikal View Post
        lol...yes and no. You will gain lateral and longitudinal grip, but the wider-than-optimal wheel to tire ratio will slightly dull response time. Still worth it to me (I run 225/50 on my 15x7's).
        That's in line with what I was expecting you to say. I've run 215/60/14s on 14x6 caps before, so I think it'll be better than that.
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          My 89 325i has two new falken ziex ze 502 205 40 16 in the front and bald falkens in the back. There on Lenso BSX which i beleive are 16x7.5. I cant seem to source the falken 502 - 205/40/16.....Should i just try and by the same size tire in the back and call it a day or would you suggest purchasing a different tire size? Any tire recommendations ?
            Okay, I'm asking this for a friend and I don't feel like reading 3800 posts. He has a late model with unrolled fenders. He is going to install eibach pros so they won't be stiff and he is running a 15x7 et12. He currently has 195, 55's and we know 205, 50's shouldn't have any issues. Would he be able to run anything wider without having any rubbing issues? If they were et20 or so I don't think it would be a problem but he is concerned due to the lower offset.
              E36 5 lug? Which coilovers? Your setup is unique enough that I may not be able to give you a precise answer.
              Yes, E36 5 lug. B&G coilovers.
              16x9.5, et 35 on an E30, 5 lug with coilovers. What kinda spacers are needed?
              If you cant give me a precise answer, something that will be slightly stretched, but have the same overall height will work just fine for me. Thanks!!
              My previous build (currently E30-less)
              http://www.r3vlimited.com/board/showthread.php?t=170390
              A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                m3 wheels
                hey guys i got the rear wheels from a m3 today... it looks like a z3 but said m3... they are real wide... 245/40/17 i want to put them on my e30.. where can i find some wheel adapter from 4x11 to what ever those wheels are? also would they even fit? i have h&r springs... what if i put the stock springs on the rear? thanks for the help
                  those wheels are 5x120 bolt pattern but I do not know if you are going to be ble to fit them.
                  CHEAP REBUILT INJECTORS
                  Need Quality Brakes? BimmerBrakes has it!
                  For anything Else go with BluntTech!
                    trying to fit a 225 45 16 on the rear should i go et15 or 25 ? dont mind rollong the fenders but dont want poke.lowered with h&r race.
                    thanks
                      So I'm getting ready to pull the trigger on rubber for the E30 M3 and in my searching I have come up with a few questions. The wheels are staggered Hartge Type-A's in 16x7.5 Front and 16x8.5 Rear.
                      At first I really wanted to run a square tire set up with 225/45R16's. Now however I'm thinking of going with a staggered set with either 205/55's or maybe 215/40's in the front with the 225/45's in the Rear. Would the square set up look too wonky on the staggered wheels, there's only a 1" difference after all. If so, what would be the best option between the two front sizes? FWIW, Hartge originally mounted 205/45's Front and 225/45's Rear (as shown in pic below). I'd like as little difference in contact patch between the two axles, and as much understeer prevention as I can get.
                      As for tire selection, I'm pretty much set on Toyo R1R's, but the BF Goodrich KDW-2's are significantly cheaper and seem to get pretty positive reviews. The Toyo's would only work on the square set-up too due to their smaller size selection. Are the Toyos really worth the extra cash over the BFG's?
                      What says the hive mind, and more importantly, the Guru?
                      1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
                        so i just picked up some kosei k1's, 17x7.5, et 45, there are 201/40/17's on them now.
                        what kinda trouble am i in for with this offset and rim size on an e30, i'm from honda world so take it easy on me..lol
                        oh i have both a 91 318i and a 86 325es..neither has been lowered yet
                        "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
                        1991 318is - the cruiser
                        1989 325i - the rats nest
                          You are gonna need at least 20mm spacers with those wheels. Never heard of a 201 section width though...
                            damn that, might just sell these for a profit..i'm not a big fan of spacers
                            205 sorry...
                              thanks
                              I can speak from experience, go for the 25. I run the TRM C1's in et25 with my 225/45-15's.
                              Lowered suspensions may need some rolling in the rear, front on my drop kit is all the way low with no issues.
                              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                                thanks ! will I lose a lot of dish going et25 vs et15 ?
