Originally posted by drivnvordaedge
View Post
This is a sticky topic.
Originally posted by mikejungle View PostHey guys, I've got BBS RA's: 6j x 15 x H2 (what does H2 mean?)
it also says "253 ET30" on it...don't know what that means either.
What's the widest I can run on em, what sidewall height do you guys recommend and should I put thinner tires up front? I think I have 205/50/15 on the back and 195/50/15 on them right now.
Oh, also, what brand and type of tire do you guys suggest? Should I search around for a used set or should I get brand new?
That's a lot of questions, but I didn't want to get flamed for starting a new thread.
Thanks
Originally posted by tfritz View PostWhat size tire for a 16x7.5 with either a 0et or 5et (offset of rim is either 20 or 25, I dont recall, and I will be running 4x100 to 5x120 adapters). Car is sitting on H&R race springs with 15mm drop hats.
Thanks.
Mystikal, I'm new to the site. Just picked up a 90 4dr and it has some rota 15x8 e4 wheels currently with some falken all season 195 50 15s. Car is lowered on GCs and fenders are rolled. How much tire can I fit do you think? BTW I am deciding between XSs, Azenis, RS3s, and Star Specs.
Thanks!
Originally posted by silver4dr View PostMystikal, I'm new to the site. Just picked up a 90 4dr and it has some rota 15x8 e4 wheels currently with some falken all season 195 50 15s. Car is lowered on GCs and fenders are rolled. How much tire can I fit do you think? BTW I am deciding between XSs, Azenis, RS3s, and Star Specs.
Thanks!
Originally posted by Mystikal View PostSo they're +4 offset? Your tire size is about maxed out then, but if you're willing/able to roll more then 205/50 is in the cards. I've used all four of those tires and have a soft spot for the R-S3 right now. Star Specs are unbeatable for wet/dry combo though.Originally posted by blunttechAlways Always go for the reach around if there is an option
Originally posted by Mystikal View PostThey're 15x6 +30. 195s are the widest you're going to want to run on a 6" wheel...205/55 is possible but not optimal. 195/60 or 195/55 are closer to the proper diameter.
Will there be a noticeable decrease in performance when I make the drop from 205's to 195's? Or will it feel better because it's "optimal"?
Thanks.1985 325e
mods:
Powerflex CABs
MOMO Corse Exhaust
euro bumpers with BBS front spoiler
e36 m3 shifter
uuc clutch stop
Originally posted by Mystikal View PostWhy run E36 offset RX's with E30 M3 suspension? They'll work with 15mm spacers, but the proper offset versions look much better (concavity).
So ill be needing 15mm spacers to clear the strut? ... test fitting it seemed like it cleared but very close to the strut for the tire
.... what would be an optimal tire size?
