	This is a sticky topic.
 Neither are ideal (fill and drill is putting a lot of trust into the guy doing the machining and the offset of the weaves is already quite low to be running adapters). E34 weaves are 15" anyways, it's a lot cheaper to just buy 15" 4x100 euroweaves.Comment
 Would it be better to run 215/35/18's or are the 225/35/18's going to be small enough to give the car a nice stance on coilovers and 18's?Last edited by googone20; 01-28-2011, 03:07 PM.Comment
 My car is lowered about 1.75 inches. The rims come in 16x8, 16x10.MiM: 10mm rear spacers, 195/55 tires
 Diamond: 15x8.5 +13 15x9.5 +13 would be beautiful (if possible). 205/50 and 215/45 tires. This will require a flat fender roll as well as linear springs (coilovers). For unrolled subtract an inch from each wheel and back the tires down to 195/55 and 205/50.
 I want to do 16" steelies. 16x10 may look dope, but may be a little excessive? Would 15's still tuck with the drop i have, would they be better?
 What et 16x8 could I do? Got this email when I asked them:
 What size tire would be best for pairing with the rim recommendations? I want a little bit of stretch, but still drive-able. I've been pouring over all the internet resources I can find, but this is all Greek to me.We offer the 16x8 with a maximum offset of +12mm. We work in every 1/2" increments or (12mm) down to - 100 mm. The 16x10 is available in a maximum of +25 mm offset down to a - 100 mm also.
 BillLast edited by MaxBell; 01-30-2011, 08:17 AM.Comment
 I want to run 4x100, 16x7.5 et35 RH ALLURAD wheels w/205-45-16 tires on my 1987 325iC that is sitting on a set of cabrio spect H&R sports. I test fitted a wheel and it just rubs the strut tower ever so slightly with the lugs tight. What size spacer do you guys recommend? I don't want to roll the fenders just move the wheel out a little.
 Thanks,
 Jasonsigpic
 "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."Comment
 alright, im puzzled
 I have a pair of Brock B1 17x8.5 et 13, they dont clear the stock brakes without a rather large spacer.
 I see Brock makes the same wheel but with a 35 offset. where will this position the wheel?
 I've used the offset calculator but I dont understand what they are saying.
 any help?
 mtech1/2jzgte/r154/275tire
 function>formComment
 I have an early model and am looking at diamond racing steelies, 16x8 up front with 195/45 tires and 16x10 rear with 215/45 tires. Im thinking 0 offset in front but im not sure what offset i should run in the rear. Its gonna be pretty dumped with rolled/pulled fenders and im trying to get it nice n flush, any advice on rear offset or anything else i should know?
 86 Zinno es
 M50 insideComment
 25mm front 30mm rear would be perfect. Will need a flat fender roll in the rear; if you get high enough spring rates (say, over 600) and roll the lip flat another 5mm of spacing would be easy.Comment
 16x10 won't work without extremely stretch tires and the work that goes with it to make such a setup look good. Probably not for you...My car is lowered about 1.75 inches. The rims come in 16x8, 16x10.
 16x8 +12 is very nice, match those with 205/45/16 tires and you have a nice setup. Maybe add 5mm rear spacers to even it out a bit, but you will need a fender roll.Comment
