	This is a sticky topic.
 Need help. Put new Ronal LS 7.5 x 15 wheels with Falken ZIEX 912 225/50x15 tires on my 90 325is (stock suspension with 15 mm drophats) and the front wheels and tires are rubbing. Left wheel is just slightly rubbing on strut but right wheel is clear by about 1/8". It appears inside wheel hubs are scraping against brake calipers.
 I don't have any experience with spacers. Can I put spacers in the front to solve this problem? If so what size? Are there specific requirements for inside and outside diameter? I bought some 5 mm spacers at a local parts store with 77 mm id and 144 mm od. Will these work?Last edited by jjc-hi; 02-05-2011, 07:06 PM.Comment
 Helo guys, I know that probably this Question has been made before but cant find it, I have 325e 88' with factory botlecaps, it comes with 195/65 14, but where I live that tire is allmost discontinued, there are very few of them and very expensive. Which tire can I change that is more common, the car is for daily drive, I have been thinking in 185/65 14, any coments would be welcome, thanks.Comment
 I've got a lowered 318is with 3mm spacers in the front.... Wondering if I will be able to fit 17x7 sacchi s45 rims... with I believe 40mm offset.
 Any input on those rims?Comment
 e30
 looking for spacer sizing.
 wheels: 16x8 et23 all around
 tires: 205/45/16 or 205/40/16
 suggestions? 8mm front and 15mm rear???1990 325i - Current Project
 2007 Triumph Speed Triple 1050Comment
 okay, i'm a dummy when it comes to offsets and what not. so I'm looking at running these wheels(http://www.1010tires.com/wheel.asp?w...ld&pc=52267087) on a 325i. what offset or wheel spacers will i need to get flush?Comment
 Looking at running 17x8.5" ET 25 front and rear with equal size tires. Hoping to run a 215/40-17. 1990 325is.
 Will this setup clear in the front, both inside and on the fender lip?
 What size spacers in the rear would give me nice flush (not looking for big poke) fitment.
 My fenders are rolled (NOT pulled) and I am slammed on coilovers with camber plates in the front.
 For reference, I am NOT looking for the POKE found with a 16x9 in ET15, the rears look great, but the front just looks silly IMHO.Comment
 haha, my turn. Just bought a e39 2000 528i touring. Previous owner installed american racing wheels on it and I just dont like it. I have a set of E38 weaves off an 740i, I know I would have to open up the bore to 74.1 but other than that they should fit, correct ? Im wanting to install 245/50/16's on them. Car currently has 235/45/17's which are only about 1/2 wider than 50/16's. Will I have to space since the offset is 23 on the 16's and 20 stock ? THANKS[sigpicComment
 I want to fit 225/45 on a 16x8.5 et19
 Suspension: e30 m3 5lug
 H&R sports/Bilstein
 E90 drop hats
 25/22 sways
 I know I will need spacers in the front (wheels are 5mm max from the struts)
 If I want as much poke in the back should I use 10 or 15 mm spacers in the
 back?
 Thanks
 Charley
 5mm would make them 25 offset, but that's probably not enough spacing to fix your wheel hub issue. I can never recall stud lengths, no idea why. I won't be much help here.So I have a set of BBS RA's that are 14"X6.25" with an offset of 30. The stock stud length is too short for me to mount them. The 45mm spare studs I have are too long (rubbing wheel hub innards). So, since I have the longer ones, what size spacer would I need to get an offset equivalent to like 25?Comment
 5mm front spacer to clear the struts, 10mm rear to even out the fitment. Kumho XS is an amazing tire, but wet traction and treadwear aren't exactly their strong suit. Not sure what else is in that size, Falken FK-452? Decent tire.What would be the best offset to run on a 16x9 wheel for a square setup. I have camber plates in the front, so I can adjust from there. I would be running a 215/45/16 as well. I don't mind a flat roll on the fenders, but would like to stay away from pulling them. I would like fitment close to this:
 He is running 16x8s with +5 in the front, +3 in the rear and a 205/45/16.
 Also, any recommendations for a 215/45/16 tire?
 Thanks!Comment
