This is a sticky topic.
So I am looking at getting a set of the xxr 527 wheels, and they run in 2 sizes that I would like. 17x8.25 with +25 and +35 offset. I was just curious if I could get away with running the +25's on the front and rear with 235/40/17 tires. I don't mind doing fender rolling either so that is not an issue. I was just worrying about the front being poked out to far with the +25's, or will it be fine?
Yes, the fronts will be slightly poking without camber plates and around -3 degrees set. The rear will need a flat fender roll and decent spring rates.Comment
She recently got a 91 e30 vert. plastic bumper front - aluminum bumper rear - cashmerebeige - tan - black top. I ordered the eibach springs 1.7"front and 0.8" rear drop, with the bilstein sports.... Gonna cheap out on the wheels and go with esm 012s in gold.
17x7.54x1002057.1
17 X 7.5 et20..... can i run 215-40-17 with no problems.... she's pretty peeved that the 19 X 9.5s have been rubbing the rear arches of her B6 passat for the last 2 years:mrgreen:Comment
Hi Mystikal I have 16x9 Borbets et15 the previous owner was running 215/40/16's I think the tire size is too small ( IN HEIGHT). What do you think? It is going on a 87 convertible with a ground control coil over kit 450/750 spring rate. I'm trying to pick new tires up before the weekend. Thanks for your help...
edit: I did a check on 1010tires.com it seems on paper a 225/40/16 would be almost perfect. But I think with my offset and not really wanting to roll fenders too much I cant go that wide???? Thanks againLast edited by ill4noreason; 05-18-2011, 04:57 AM.My Multi car part out. Need a part? Pm me...
http://www.r3vlimited.com/board/showthread.php?t=193051
Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
http://www.r3vlimited.com/board/showthread.php?t=215044
Have you done business with me? If so leave me feedback here...
http://www.r3vlimited.com/board/showthread.php?t=188307
Would 17x8" wheels with 20mm offset and 235/40R17 tires fit on an E30 with an E30 M3 5-lug swap? What kind of fender rolling and/or spacer would be needed?Comment
Wait what's the width, 8.5? Assuming yes, your front strut clearance will be minimal and will probably just touch when you mount the tires. You'll want 3-5mm spacers to clear safely.
just a heads up to anyone wanting to run iX wheels on a RWD E30, there is a good amount of misinformation out there and i was mislead which caused me to waste $70 on the wrong size of spacers.
you need at least 5mm for ONLY the rim to clear, if you have wheel weights they hit the strut, i have 205/55 tires and they sit tight to the strut. you need at least 10mm in the front if you want the tire to clear.
Originally posted by nwvb bmwThat guy is going to lock you in his basement and make you ware a little pirate costume.Comment
^You can order adapters from:
LedJetta (member here and dealer for Adaptec)
Motorsport-Tech
These would be the two vendors I would do business with when it comes to adapters. I'm not saying any other companies can't/don't make high quality products, just that these are who I would personally use.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Motorsport-Tech
These would be the two vendors I would do business with when it comes to adapters. I'm not saying any other companies can't/don't make high quality products, just that these are who I would personally use.Comment
Okay,
Just bought some 16x7 BBS CH's ET43 off a member here.
I'm going to put 215/45/16's on them (225/45/16 selection sucked, couldn't find any good prices or tire selection).
How well will these fit, ignoring the centerbore (they're being bored from 54.3mm to 57.1mm).
Will I need spacers, or will I be able to run them without? Ideally I'll run them without, for cost effectiveness, but if I need them, what size would you guys recommend?
My E30 is a 91 318iC, sitting on Ireland Engineer Stage 3 Race springs.
Any help is appreciated!Comment
