This is a sticky topic.
  • brian52555
    • 425
    #4351
    Need some help:
    Currently running 15" BBS RZ 392 15x7 rims, et 25mm. With Falken RT-615s at 205/50.
    I have AST coilovers, lowered about 2 inches. I have about 3-4 fingers of fender gap.
    Here is the problem:
    I have a set of track wheels waiting to go on, D-force 15x7, with 225/50 Toyo RA-1s. So far, I've only test fitted the rear wheel, and it doesn't seem to rub at that static height, as there seems to be about 2-3 fingers of fender gap.
    I am going to put on a UUC BBK in the front, I need to know the max size spacers I can run on an et 25 rim. For the D-force wheels, they are supposed to be direct fit and I won't need spacers. But for my street setup with the BBS rims, I've used the wheel template and I think I will need at least a 12-15mm spacer up front. With that said, should I purchase spacers for the rear to move the track width out as well?
    Lastly, will I need to roll my fenders with my 'track' wheel setup at 225/50 with the 15x7 dforce rims?
    Thanks.
    • twigg
      • Apr 2011
      • 100
      #4352
      I have an 89 325I with eibach lowering springs and e90 drop hats and just picked up some rs's that are 5x130 and 16x7 16x8 both et 49 what size adapters and tires I do not mind rolling fenders I want the lip close to flush as I can.
      • e30BMart
        • Feb 2011
        • 658
        #4353
        Are these a good idea for an e30? http://montreal.kijiji.ca/c-ViewAd
        Will they fit?
        • rich4rdee
          • 595
          #4354
          i'm looking to replace my stock 14" basketweaves with 17x7.5" borbet type C with falken 912 wheels. (205) i'm running bilstein sport shocks and h&r race springs with the e92 drop hats on a late model 325is. will i have rubbing issues? will i need to get my fenders rolled?
          thx for this!!
          • mayko
            • Dec 2010
            • 13
            #4355
            Mystikal,
            I have 205/50 on 16x8.5 et32 and 225/45 on 16x9.5. What adapters do you recommend? I have seen other guys running the 16x8.5's front and rear with 20mm adapters but with 195/45 tires. I foresee clearance issues, if I copy the same set up, since those tires are far more stretched than what I have. I have a late model car, lowered, and do plan on doing some fender work. Please advise, thanks.
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #4356
              Originally posted by ill4noreason
              Hi Mystikal I have 16x9 Borbets et15 the previous owner was running 215/40/16's I think the tire size is too small ( IN HEIGHT). What do you think? It is going on a 87 convertible with a ground control coil over kit 450/750 spring rate. I'm trying to pick new tires up before the weekend. Thanks for your help...
              edit: I did a check on 1010tires.com it seems on paper a 225/40/16 would be almost perfect. But I think with my offset and not really wanting to roll fenders too much I cant go that wide???? Thanks again
              I agree, I rarely recommend that size despite it's popularity. Been trying to rid the E30 game of that undersized mess for years.
              205/45 is perfect. It'll even appear to be stretched slightly less, despite the narrower section width.
              • Mystikal
                • 9602
                #4357
                Originally posted by twigg
                someone has for sale a set of ronal five star wheels that are 16x7 et 23 bolt pattern 5x120 I want to know what size adapters would I have to run and tires if they would fit. I am also on eibach springs. Thanks. Sorry for no pics on my cell
                Smallest adapters possible (18-20mm) and the smallest tire possible (like 195/45/16). They'll be flush.
                • Mystikal
                  • 9602
                  #4358
                  Originally posted by Panderp
                  A 17x9 +25 offset. What size tire/spacer (if any) would I need to run?
                  Thank you.
                  10mm front necessary, nothing needed in the rear but will look a little off without spacing (relative to fronts). Stretched tires needed - 205/40 or 215/40 (the latter needing fender rolling).
                  • Mystikal
                    • 9602
                    #4359
                    Originally posted by bubbajan21
                    Would 17x8" wheels with 20mm offset and 235/40R17 tires fit on an E30 with an E30 M3 5-lug swap? What kind of fender rolling and/or spacer would be needed?
                    Not without a noticeable fender pull, even on a early car. No spacers.
                    • Mystikal
                      • 9602
                      #4360
                      Originally posted by saxguy09
                      thinking about picking up some wheels from a buddy to ditch my borbets. they are 15x7 so i know ill have clearance but the offset is 38, i think they are sportmax 002, will they fit
                      They should just barely mount, but will probably contact the strut depending on the tire mounted. 15-20mm spacers needed.
                      • Mystikal
                        • 9602
                        #4361
                        Originally posted by ricerscott
                        The width on them is actually 8.25 and not 8.5. Will the front still poke out or be pretty flush?
                        Interesting on the 1/4" width increments. Haven't seen that mass produced ever.
                        Front will be fairly flush depending on how you judge that sort of thing. It won't rub, but the tire will be bulging slightly outside of the fender line.
                        • Mystikal
                          • 9602
                          #4362
                          Originally posted by rennis
                          Question: With adapters, will these work well on a e30 'vert? Thanks!
                          BBS RS 174 fronts and BBS RS 244 rears.
                          Fronts: 16x7 et33 5x114.3 73mm centerbore
                          Rears: 16x8 et33 5x114.3 73mm centerbore
                          20mm adapters all around, 205/45 front and rear (or 215/45 rear for an even stretch/sidewall angle).
                          • Mystikal
                            • 9602
                            #4363
                            Originally posted by brian52555
                            Need some help:
                            Thanks.
                            You can easily get away with a 15mm spacer up front with your 205 tires and RZ's. No fender rolling needed for the track setup.
                            • Mystikal
                              • 9602
                              #4364
                              Close to flush? You'll need 50mm adapters for that. Even better would be smaller adapters (20mm) and wider lips mounted. You can easily get those to 16x8.5 and 16x9.5 and end up with an ideal +10 offset front and rear. Just something to think about.
                              • Mystikal
                                • 9602
                                #4365
                                Will they fit?
                                Can't see the ad.
