This is a sticky topic.
  • London
    • 532
    #4756
    No question, just saying thanks Mystikal :D
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #4757
      Originally posted by AE86
      looking to buy a low offset wheels with the following specs 15x7 et 10 (FRONT) & 15x7 et5 (REAR), can i run this offset? Also would be able to run 225/50/15 tires? Thanks for info.
      Limited to 205/50s even with a flat rear fender roll.
      And to everyone who posts thank you's, you're very welcome. I'm not an arrogant prick, I promise I read and appreciate all of the kind words. I fail to reply just in the sake of keeping the thread clean..ish.
      • Roysneon
        • 4505
        #4758
        Originally posted by Mystikal
        So you have the lower offset E31 M systems then? These will only fit an E30 with very stretched tires.
        Upon further looking they're stamped 20 and 22, I just pulled the E31 specs off google. I'm looking to not stretch, I'm only going to be on H&R race so not too low, I'm really hoping to fit the 225/235 setup.
        Originally posted by mbonanni
        I am a pursit now.
        • e30lyf
          • May 2007
          • 4516
          #4759
          Originally posted by e30lyf
          Hey Jay,
          Borbet 16x7.5 et20 and 16x9 et15. what size of tires should i run? do i need spacer for better stance?
          i'm thinking 205/45 front & 215/40 rear. lmk your opinion and what brand of tires should i buy.
          btw, i'm running IE3 w/ drop hats and koni sport on my late model
          Thank you,
          It would look a lot better with 15mm front spacers. Tire sizes are okay, but the fronts will be noticeably taller than the rears. Either go 205/45 all around or 225/40 on the rear for a matching diameter. Falken 912, BFG G-Force Sport, Yoko S.drive, all good.
          thanks for the quick response. assuming no need to roll the fender. looks like it's hard to get 225/40/16. do you have any source? really appreciated :)
          - Fercy -
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • Songj91
            • May 2011
            • 211
            #4760
            Hey I have a 1990 325is (don't know if the late year or IS model is different from other e30s)& I have bbs LM reps with a center bore 73.1mm. They are also 17x8 all around with a 40 offset :/. Im thinking of running a 225/35 all around. Beside hub centric rings, what size spacer (if any) would u recommend? Is it worth trying to make those fit me e30?
            • drumad
              • Aug 2009
              • 1700
              #4761
              For a DD, what wheel size and tires (size and model) do you recommend? I've been thinking of picking up either euroweaves (15x7) or Rota Grids/Rota Slipstreams (16x8/15x8) with probably continental contactsports or michelin pilotsports if they are available for the wheel sizes. What are your thoughts/recommendations? Just remember it's for a DD and I have my "fun" wheels already.
              Car is an 89 e30 4 door BTW and suspension is H&R sports with billies and drop hats.
              2008 335i - n54b30
              1991 318i - m52b28
              1994 fzj80 - LAND CRUSHER
              • Bora28
                • Aug 2011
                • 9
                #4762
                Hey, I just wanted a quick confirmation before I order wheels for my winter setup.
                Car: 88' 325 2dr
                Susp: Eibach springs + drophats (2"ish)
                Tires: 195/60/15 winterforce snows
                Im trying to narrow it down between these two (cheap) choices, and I want to just make sure they will be an easy bolt up and look decent with nothing too complicated aside from hub-centric rings and possibly tuner bolts.
                Wheel 1) Drag DR-20 15X7 4x100 ET10
                Link:http://www.erzperformance.com/DRAG_D...54-100gb10.htm
                Wheel 2) Konig Rewind 15x7 4x100 ET20
                Link: http://www.ebay.com/itm/15X7-KONIG-R...ht_3049wt_1034
                Any concerns, or should these bolt right up?
                Thanks in advance, I appreciate it!
                • funcrew
                  • Jun 2007
                  • 1223
                  #4763
                  Jay,
                  On a not-slammed late model with H&R OE sport springs (1 inch lower than stock) and rolled fenders, and maybe 1.5 degrees of neg front camber (fixed plates), could I get by with 16X7et25 and 225-50-16? I know they're tall, but I'd be running a lot higher than most on this thread. Thanks in advance.
                  "If the sky were to fall tomorrow, the tall would die first."
                  -Dr. Paul Forrester
                  Do I LOOK like I need a psychological evaluation???
                  • arubaru
                    • 87
                    #4764
                    Hi there, im planing to order a set of Compomotive TH 17x8 and ET could be from 15 and above. So what would be the perfect ET for the front and the rear? And the tyres?
                    I was thinkin 17x8 ET20 at the front with 205/40
                    17x8 ET16 at the rear with 215/40
                    will it fit?
                    I got already rolled the arches at the rear.
                    Thanks in advance!!
                    • rstimpreza
                      • Sep 2011
                      • 216
                      #4765
                      Anyone have fitted a 15x7.5 +16 offset on their e30?
                      • walktheboard
                        • 347
                        #4766
                        Just for clarification, 17x8 +25(aka apex arc-8s) will fit with h&r races with only mild fender work? what about a 17x9 +20, more fender work, but not too much?
                        On a late model car
                        Originally posted by e30hijinks
                        I move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play games
                        • Mystikal
                          • 9602
                          #4767
                          Stretching is 100% necessary. Even with a 215/40 stretched on all around, you'll be working the rear arches quite a bit to get them to fit.
                          • Mystikal
                            • 9602
                            #4768
                            Rolling will likely be necessary, depending on suspension setup and model year. Discounttiredirect.com for rubber
                            • Mystikal
                              • 9602
                              #4769
                              15mm front 20mm rear spacers with 73-57.1mm hubcentric rings. 215/40/17 tires (225/35 is undersized).
                              • Mystikal
                                • 9602
                                #4770
                                Totally up to you. I can tell you what fits, but I have no clue what you like.
