This is a sticky topic.
  • russ in va
    • Sep 2006
    • 15
    #4801
    Originally posted by Brew
    Weird one here... I'm looking for the minimum offset required to run a Hoosier 23x9.5-15 bias cantilever slick on the rear. Section width is 10.4", and they will be mounted on a 15x7 wheel.
    I realize the fronts will require spacers but I need to get the rears in as tight as possible for (obvious) fender clearance issues.
    Any insight would be much appreciated!
    I just came back from my first weekend running cantilevers. I went with the more rare Goodyear 23x8x15's (same size as the Hoosier 8.5"s despite what they call them). My used race slick source tells me the goodyear 9's are only 1/2" wider than the 8's for whatever that's worth. I was running 15x7 35mm offset wheels with 20mm spacers in front and 15mm spacers in the back. I had minimal contact with strut tube on one side in front and none at all in the back. Looks like the rear could move in a bit more and still be fine (I'm at net 20mm back there, I would think 15mm would be fine but it's hard to tell until you put it on track under load). My fenders are rolled but not terribly aggressively. Hope that helps.
    • Brew
      • 3060
      #4802
      Ah, fantastic info! How much room do you have to the strut in front at rest? And how much negative camber up front?
      Thanks!
      '91 318is
      • russ in va
        • Sep 2006
        • 15
        #4803
        Thanks!
        Not bloody much. I used a 3mm wheel spacer I had laying around as a feeler gauge and it would not go between the sidewall and the strut tube. You can see daylight in there but after 5 sessions when I pulled the wheels off you could see a "polished" spot on the strut where it was contacting a bit. I'm happy with it like that, I've run with much worse. Did not damage the tire at all. I'm running 2.5 degrees negative camber, but that's too much. I'm going to stiffen the car up over the winter (stock sways being replaced with 22/19mm's) and drop the camber down to 2.0 or less. I don't think that will give me any fender clearance issues but only time will tell.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #4804
          Originally posted by drummerchubbs
          Will 16x8 et 0 poke a little? I wanna stretch a 195/40. Good?
          You will end up with zero ground clearance once you get the fender height correct. 195/45 if you're dead-set on them.
          • Mystikal
            • 9602
            #4805
            Originally posted by Neil1138
            Need some help guys. Here are the wheel specs:
            E38 style 5's (R16, 8" wide, ET23, +10mm spacers all around).
            Trying to push the limits here and I'm running into issues. Currently the car is lowered (billys + h&r) but I'm going all out with shortened ground control coilovers soon. I had some 205/55/16 (turanza) tires in the garage so I tried them out (pictured) but those rub very badly. In the rear the fender lip is contacting the sidewall. We rolled it a bit but it seems like we'll have to flare out the fenders quite a bit which I don't want to do.
            In the front, while turning, the tread keeps catching the fender as well. Ultimately, it doesn't seem like 205/55s are possible with these wheel specs on a slammed car. I've seen quite a few e30s with 205/40 and 205/45 tire setups. I feel as though those tires are a bit small though, they don't quite fill the wells. My question is, are 205/50s possible?
            205/45 is the key size for that setup. The offset is too low (Read: flush) to run a stock diameter tire.
            • Mystikal
              • 9602
              #4806
              Originally posted by GunMetalGrey
              Question Time, ESM 004's for my m50 swapped car. I plan on boosting this car so I want to get something that will give me the grip I need for when it gets boosted(shooting for 500whp). I also like dished wheels, and want the ESM 004's, could I get away with running 17x9's with a 40 or 25 offset? I can run spacers if needed. I am not a fan of stretched tires, and am not really willing to run them. I could deal with a slight stretch but not much because I would like to keep it functional. And I won't run into any issues with 9's in the rear correct? Thinking somewhere along the lines of a 275/40/17 in the rear. I have thoughts of running a widebody, but that is a whole nother deal. If I can fit them under pulled rears that would be great, I am open to opinions!
              17x9 +25 with a 245/40 and severely pulled rear arches is about the limit for stock fender material. Obviously with widebody my opinion is useless as you can build it to where you need.
              • Mystikal
                • 9602
                #4807
                Originally posted by jizo
                I have a set of BBS RS that i just staggered, 15x7 in front and 15x8.5 in rear. What size tire should i run? people suggest 225/45 15...but to scared of this setup. was thinking giving the rear some stretch but would like them to be safe. Gonna run a GC full coilover setup if that helps. Rear fenders are rolled flat. BTW...et20.
                here is a pic of the rear.....
                It would be very strange if your front and rear offsets were both +20. Double check that.
                • Mystikal
                  • 9602
                  #4808
                  Wish I had info to add (russ is va - thanks!). I have always had very little reference points for absolute E30 inside rear clearance.
                  • drummerchubbs
                    • 512
                    #4809
                    How about 205/40/16. With 16x8 o off set will I have clearance for struts? Thanks for all your help.
                    SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
                    • Neil1138
                      • 527
                      #4810
                      Thank you sir, I appreciate it!
                      • RLloyd
                        • Jun 2011
                        • 43
                        #4811
                        Looking at some TRMotorsport C3M's on tirerack, 15x9 et36 I believe...
                        New to e30's but Im guessing I will need spacers all around and a fender roll. Can anybody confirm the specifics? Thanks!
                        • Vp special k
                          • 90
                          #4812
                          how much backspacing is needed to clear the front and rear?
                          • OrangeFiero
                            • Nov 2011
                            • 350
                            #4813
                            I found some momo quasar deep dish rims (almost 3" dish) with not much offset. Has anyone used these wheels on an e30? How do they fit? They are 15x8 i believe
                            John 16:33
                            • jb35
                              • Nov 2008
                              • 15
                              #4814
                              I am trying to get more grip for autocrossing. I am currently running 205 50 15 and cannot get them hook up. They did fine until I put a Eaton M90 on the M20. Looking at running 17x9 and 17x10. The backspace is 6" on the 9" and 6 1/4" on the 10". I am also going to run bolt on flares. So my question is will the backspacing clear and how much should these stick out on a stock 87 325is. Also any ideas on tire width. I would like to use a 255 rear and 245 front.
                              • ACHTUNG
                                • May 2005
                                • 2397
                                #4815
                                Mystikal -
                                Wheel: Ronal LS 7.5" ET25
                                Tire: Hankook RS3 225/45/15
                                Can I run 15mm spacers on the front and 20mm spacers on the rears without rubbing? Would I be poking either in the front or the rear?
                                1989 US E30 Cammed S52
                                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
