Thank you sir.
And I should be able to fit a 215/50 maybe 225/45 in there right? No care about fenders, may do flares.
Not going for stance here, but I want wider tires for track and since I couldn't find any decent 8x15's, I'm going with the OZ Vega 3pc'ers I had lying around.
Will post results when I glue these babies back together.
Thank you sir.
225/45 is an easier fit than 215/50. You will be pulling the fenders or adding flares to make that work.
Test fit the wheels without spacers first. I have great success with BC's and aggressive wheels on BMWs, but we have yet to install them on an E30. With a stock setup you'd need a 3mm spacer to clear the fronts safely. But I have a hunch that it just might clear the BCs, especially if you didn't go for too long of a spring.
As for tires, 205/45 front 215/45 rear for even fitment. 215/45 all around for performance (with rolled rear fenders).
What if i were to get ones that were 6.5 inches wide but still et40? as ive taken half an inch (approx 12.5mm) off the width with the same offset. Would i still need to run spacers?
Side note would the setup in the post above mine (16x8 et10) work without spacers?
Basically is just like to know what wheels i can run without spacers as id prefer not to run them for safety/illegality reasons.
16x8"
Et11
205 50 16's
Late model
H&R Race's
BMW offset front strut mounts
Fender lips rolled, but NOT pulled
Fit?
Yes.
What brand and model of tires?
Because the thing with different tire brands is, some stretch and some don't even though they are the same size.
I am running Gruppe-Gs. Same weel setup. But ET15 Front, ET8 Rear.
