This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4891
    Originally posted by bannre10
    What if i were to get ones that were 6.5 inches wide but still et40? as ive taken half an inch (approx 12.5mm) off the width with the same offset. Would i still need to run spacers?
    Side note would the setup in the post above mine (16x8 et10) work without spacers?
    Basically is just like to know what wheels i can run without spacers as id prefer not to run them for safety/illegality reasons.
    6.5" +40 can clear, but it would look ridiculous. Do not do that!
    16x8 +10 works. I recommend 16x8 +15 with a 205/45 as a great middle ground setup.
    • Mystikal
      • 9602
      #4892
      Originally posted by mach schnell
      16x8"
      Et11
      205 50 16's
      Late model
      H&R Race's
      BMW offset front strut mounts
      Fender lips rolled, but NOT pulled
      Fit?
      Very tight fit in the rear, but your 570lb/in worth of spring rate should help. I'd go for it.
      • homegrone30
        • Jun 2007
        • 1449
        #4893
        Ok this is my first try lets see if I can get you everything. I'm ok with a little fender rolling but I don't want to go crazy, and do I need adapters to run these. So my question is what size tires should I run and what width do I need to order my adapters?
        1990 325i
        Vogtland springs
        Bilstein sports
        Flipped Akg subframe bushings
        Wheels: Ruote O.Z. 15x7 et35
        • drummerchubbs
          • 512
          #4894
          Will 16x8.5 et32 and 16x9.5 et 38 corvette salad shooters fit with adapters? Will in need spacers? How much of a roll/pull?
          SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
          • txleadfoot
            • Apr 2006
            • 208
            #4895
            Spacers for 15"x6.5" ET33
            I have 15"x6.5" ET33 BBS RZ wheels (VW Corrado) mounted with 205-55/15 tires. None of my fenders are flared and I don't plan to. I've calculated the offset difference between my wheels and the factory euroweaves gives me about 15mm difference. Given that, what width of spacer would be appropriate to move the wheels out a bit closer to the fender without rubbing?
            Thanks!
            • tea2jay
              • 73
              #4896
              What's a good tire size for 15x8 et25 wheels? Car will be lowered on jom springs/shocks on my 87 325 vert. Don't drive aggressively so I don't need super meaty tires or anything like that.
              • Jozi
                • 244
                #4897
                16x9 ET15 all round.
                Bc racing coilovers
                late model
                I have a 225/40 and 215/40 but they look to low profile going by above posts. Was hoping to fit the 225 on the rear, will need a bit of work but not to worried as the car is going for a full respray.
                I think 215/45 is the right size tire? How would 225/45 fit on the rear? Not a big fan of stretching tires + 215/45 are expensive (more so than 225/45) unless I go 205/45 which might be a bit much of a stretch?
                I'll also be running with ix arch flares (not a ix E30), hoping to have the wheel nice and flush, bit of poke would be ok. Have camber adjustment out rear which I was hoping to use to dial out camber, I've a little bit of room to do arch work before I run into probs with the ix flares.
                • noE30
                  • Jun 2008
                  • 2259
                  #4898
                  two questions:
                  89 325i coupe
                  17x8 et 20, What size spacer would you recommend for a flush fit? Tire size?
                  16x8 et 48, what size adapter?
                  edit: would a 20mm adapter work? leaving a final offset of +28
                  Thanks a lot!
                  Flickr
                  @michael.colby on Instagram
                  "All he needed was a wheel in his hand and four on the road"
                  • gswrs
                    • 24
                    #4899
                    I have a 1990 325is and am going to buy 16x8 wheels.
                    question is i need to know what offset
                    ET 0? OR ET 20? im leaning towards ET20 because the lip on the wheel is 2.75 vs 2.50 on the ET20. HELP!
                    • Mystikal
                      • 9602
                      #4900
                      1990 325i
                      Vogtland springs
                      Bilstein sports
                      Thinnest adapters are typically 18-20mm, so you'll end up with a 15-17 final offset. This is doable with a 205/50 tire and a rear fender roll.
                      • Mystikal
                        • 9602
                        #4901
                        20mm all around should be good. 195/45 F 215/40 R. Just a flat rear roll.
                        • Mystikal
                          • 9602
                          #4902
                          Thanks!
                          15mm is fine.
                          • Mystikal
                            • 9602
                            #4903
                            You'll need 3-5mm spacers to clear the front struts. 205/55 or 205/50.
                            • Mystikal
                              • 9602
                              #4904
                              Bc racing coilovers
                              late model
                              The taller the sidewall, the more fender work you will have to do. 225/45 will require HEAVY fender modification. I typically suggest 205/45 for a good balance of ground clearance and wheel well appearance.
                              • Mystikal
                                • 9602
                                #4905
                                Originally posted by noE30
                                two questions:
                                89 325i coupe
                                Thanks a lot!
                                It's hard to get 8" truly flush, especially 17s. I'd suggest 5mm F 15mm R with a 195/45 all around.
                                16s will need 25mm to clear the struts safely.
