16x7, et-1 and 16x8 et-14. Pulled front fenders, aggressive roll on the rears. Should I go 205/50 fronts, 225/50 rears or would I be safer going 205 all around? Thanks!
This is a sticky topic.
Anyone know what type wheel this is on the M3?
88 M3 Diamantschwarz
89 M3 Zinnoberrot
56 Isetta
LIKE ARCHIE'S on Facebook!
www.facebook.com/archiesicecreamComment
Mille Miglia 1000. Wrong thread though ArchieAnyone know what type wheel this is on the M3?
http://www.uniqueautoexchange.com/ve...Illinois-60155
89 M3 Zinnoberrot
56 Isetta
Isn't the issue how cold can it get before your car slides into a lamppost the first time mother nature thinks about non-liquid water (like frost)?I'm changing my question:
I'll be purchasing a set of Yokohama S.Drives soon. I've read a bunch of reviews and I really think they're the best tire for my budget. I realize these tires are not built for winter. But my question is, how much of cold temperatures can they endure before getting damaged?
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
17x10
+ 20
DTM Fiberwerkz fender flares (~2 inches wider than stock flares)
Coilovers
I want grip, lots of it, prefer to not stagger. Tire size?Comment
Fitment and tires question:
I am buying some Borbet BS that are 16x7.5 et 35. (What tires can be run and are some sizes usually cheaper than others?)
I currently have some 10mm hubcentric spacers but the hub diameter is for bigger size like honda, etc.
I was planning on having the raised lip of the spacers ground off and just use them as 10mm non hubcentric spacers. (Is that safe and ok?)
Car is stock height but I am installing an M50 which will probably drop my front end a bit due to the added weight but if it is not enough I will go to lowering springs or those jom coilovers. (Will that affect my tire choices?)
Sorry for all the questions but I appreciate any help.sigpicComment
Hey guys, i've been back and forth between what kind of wheels to get after the swap is done. I just sold the esm reps (no more reps ) which were a square 16x9 et 10 215/40/16 setup. I felt the car had to be to low to pull of the small stretched tires and with the condition of the roads I spent more time pothole scanning then enjoy my drive. I'd like to get some meaty tire to accompany the massive power boost (think 225/45/16). So now if I'm shopping to have some wheels custom built to my spec and wanted to get your guys input on build specs. I was leaning towards 16x8 et 20 to fit the larger tires but also be able to lower the car enough to achieve a healthy balance (full gc coils with camber plates). So basically if you could build your wheels to any spec with respect to having a proper tire, what would it be?sigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/Comment
Put the 16x8s up front and buy 2.5" lips for the 16x7s. Net result is a 16x8.5 +6 (awesome). 205/45s are perfect.BBS RS 16x7 et25 (1' lip) and 16x8 et12 (2' lip). i want to change the lip. how wide i can go to get flush/stance? TIA
for now i'm running koni sport and IE3 w/ drop hats on late model. i might upgrade GC coilover soon. i have tires 205/45/16 never been mount on those rims.Comment
Very aggressive. With enough rear arch massaging you can make it work.How would E38 Style 5's (16x8, et23) fit on 18mm adapters (minimum, can be 20mm) while on 205/45/16 rubber? It'll be on stock 325i suspension and then on BC coilovers, opinions on both suspension setups would be the bee's knees. I'm be using the adapters temporarily while I assemble my 5-lug conversion parts.Comment
