This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5206
    Originally posted by e30BMart
    hi! first time posting on here! i wanted toknow how Direzza Sport Z1 Star Spec 205/50r15 dunlop star spec sport z1's on 15x8 TRM C1's will fit on 318is 1991? ( i think the offset is +20 ) but am very uncertain. thank you!!! ps will i need to roll fenders because im dropping as low as i can ( have coilovers )
    No rolling needed.
    • Mystikal
      • 9602
      #5207
      Originally posted by e30lyf
      thanks much Jay...
      what's the camber should i expect on this set up?
      No way to predict that.
      • Mystikal
        • 9602
        #5208
        Originally posted by Jezza
        So I'm trying to roll my rear fenders but there is some kind of lining that wont let it fold all the way back. Anybody have any idea what this is and can it be removed? I saw on a thread on another forum about some e46 guys having the same problem and that it was some rubber lining.
        Hardcore undercoating? That didn't come from the factory.
        • Mystikal
          • 9602
          #5209
          Originally posted by euronotworthy
          How bout 16x8/9 et 20 on 215f 225r/40/16...?
          Perfect. I'd go 205/45 on the front though.
          • Mystikal
            • 9602
            #5210
            Originally posted by mbonanni
            Racing hart type c.
            17x8
            et38
            Will I neeed to run spacers?
            Yes, 15mm all around.
            • Mystikal
              • 9602
              #5211
              Originally posted by Harry's E30
              Brock b1's 16x9 all around et-15 will i need spacers and if so would 1/4 be enough also debating on what tires to run 225/45 or 215/45 and how much fender rolling i will need.
              Thanks!
              225/45 won't work very well, and even 215/45 requires a very good roll + linear spring rates (coilovers).
              • Mystikal
                • 9602
                #5212
                Originally posted by Pl3wA
                ok, stock fenders. 10" wide rims... meaty tires. possible?
                It's barely possible with 8" wide.
                • bronzit_e30_fanatic
                  • Mar 2012
                  • 1
                  #5213
                  i just bought some 16x7 et 20 m68 reps for my e30, wanted to know if there will be any fitment issues on offset and if i can get the same offset as i have on my 14" bbs et 30
                  • FrozenSolid
                    • 276
                    #5214
                    hey there. front wheels are 17x7, rears are 17x8.5 both are et25. car is lowered about 2" all around, early arches. i was thinking 205/40 and 215/40, but i dont want the stretched tire look.. what would be a size bigger? any fender work? thanks!
                    • Mystikal
                      • 9602
                      #5215
                      4x100 M68 reps? Interesting. They'll fit fine, even with 225/45 tires.
                      • Mystikal
                        • 9602
                        #5216
                        215/40 F 235/40 R. Rolled rear fenders, nothing crazy.
                        • MC Hammered
                          • Jul 2008
                          • 2076
                          #5217
                          Originally posted by Mystikal
                          Yes, +23 will clear with a flat fender roll.
                          Bump it up to +28ish for a 245/40.
                          Thanks for that info! :D
                          Just wanted to clarify since you said "+28ish"... so a 17x8.5 ET30 wheel with a 245/40/17 tire will fit in the rear without issues or fender work?
                          *crosses fingers*
                          17x8.5 et15 with 215/40 and 17x8.5 et30 with 245/40 would be a nice combo.
                          My 1989 e30 s52 Touring... this is Betty
                          My 1989 325i vert (sold)...this is Nina
                          My 1991 M5 (sold)... this is Veronica
                          Photo comparison: OEM vs aftermarket windscreen for a convertible
                          • dmoney(AB)
                            • 1372
                            #5218
                            how bad of spacers would I need for these?
                            also what would be the bet tire size for them
                            17"x7.5" F +33
                            17"x9" R +40
                            mtech1/2jzgte/r154/275tire
                            function>form
                            • Mystikal
                              • 9602
                              #5219
                              *crosses fingers*
                              You *might* need to grind some material off the little protruding seam on the trailing arm (inside clearance). No biggie.
                              • Mystikal
                                • 9602
                                #5220
                                17"x7.5" F +33
                                17"x9" R +40
                                You want flush, big rubber, or something in between?
