This is a sticky topic.
  • mkcman17
    • Jul 2010
    • 8240
    #5251
    thanks, i'm going to give it a try.
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
    • Chico335i
      • 42
      #5252
      Hello, that you think of rings 17 ' x 8 et 20 for 335 85 ', I am very interested in rings of this measure and also serious which the ideal tire for these rings.
      Delphin Metalic 335i 1985
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #5253
        They're 4x100, right?
        215/40/17 will work without modification. If you're willing to roll/pull your fenders 235/40/17 can fit also.
        • Chico335i
          • 42
          #5254
          Yes 4x100, sorry..!!! It was worried if it was necessary to make some modification or use spacer, my car has a body kit Zender, this one makes it see very width so I need to refill with rubber the space of the fender.
          Thanks..!!!
          • Active16Bits
            • 132
            #5255
            Hey, I just got a set of Porsche seven slots. 16x7 et+65 The offset is crazy positive. I was wondering what size spacer/adapters and tires should I get? The adapters are going to be made to order. I'm hoping for something like this:
            *Not the same wheels.
            • BMWamongJDM
              • Feb 2012
              • 219
              #5256
              Is it possible or right to run some rotas with measurements 4x100 16x7 and offset of 40
              • drummerchubbs
                • 512
                #5257
                Front 16x8 et 3 205/40 and rear et -2. Will this work for my 89 325i?
                SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
                • tk-421
                  • Sep 2011
                  • 291
                  #5258
                  The general style discussion forum, as well as a place to post your car, or any car for that matter.
                  I PM'd him and this is what he replied:
                  "Hey man, It's actually my friends car, his name is T La on here. Not too sure how often he checks though. I did do the fender work however and the rears needed a decent pull in order to fit with no rubbing. I was able to get a good amount of space from the quarter itself. I first cleaned out all the sealant in the fender lip before rolling it flat. I only touched the fender lips towards the end to try to maintain stock body lines. The fronts are slightly rolled with camber added from camber plates. The rears are stock with no camber or tow adjustments just ground control coils on ix shocks"
                  ....Sorry Mystikal :D
                  1990 E30 325i sedan - Gletscherblau (280) over Indigo cloth (0271)
                  • kickinindian
                    • 2327
                    #5259
                    what size offset range should i look at for a 16x7 or17x8 wheel and what tire size so that i can fit on a stock or later a 1.5in drop without rubbing or rolling fenders? sorry noob question tryin to figure it out by myself and dont think im getting it right
                    • ToPLeSS(e30)FeinD
                      • Jul 2011
                      • 2813
                      #5260
                      225-35 or 225-40 on a 9.5? yes i have to stretch a bit.. no it wont look stupid. but i want to run 205-40 on the 8.5 fronts and dont want it to look too raked..
                      suggestions?
                      '89 Delphin 2.8 Cabrio
                      '94 Yamaha FZR 600
                      Originally posted by FlexdXJ
                      Is that thing on air?
                      • drummerchubbs
                        • 512
                        #5261
                        Originally posted by tk-421
                        http://www.stanceworks.com/forums/sh...ad.php?t=21035
                        Thanks buddy!!! That's what I'm gonna do.
                        • Mystikal
                          • 9602
                          #5262
                          Absolutely massive spacing. Like 70mm of it. 195/45 tires.
                          He has the staggered rears. AT LEAST having a staggered set (or ideally, a square 16x8) would make fitment and spacer sizes slightly more reasonable.
                          • Mystikal
                            • 9602
                            #5263
                            With 15-20mm spacers, yes.
                            • Mystikal
                              • 9602
                              #5264
                              +20 to +25 is a good baseline.
                              • Mystikal
                                • 9602
                                #5265
                                suggestions?
                                225/35 is the common choice. I'd suggest sticking with it.
