This is a sticky topic.
  • jdirty
    • 346
    #5281
    Originally posted by ToPLeSS(e30)FeinD
    ya that should be fine. IMO
    oaky thanks. is that with or without rolling and pulling fenders?
    • StreetMafia21
      • Sep 2011
      • 250
      #5282
      205-45 all round with 15/20mm spacers (which i have) and a decent amount of lownessocity.
      GO!
      Edit: didnt see that it was 5 lug... then just get the 18 mm adapters all around. will be easier to sell when it comes time.. and you will still be at et+5 on a 8"... pretty friggin flush
      fosho perfect thanks bra
      • Jand3rson
        • 37587
        #5283
        I have the ability/resources now to have custom-made spacers made to whatever thickness I want, and I want my new wheels/tires at flush fitment. I'm running 17x8 Apex ARC-8s with Yokohama S-Drive 215/40/17. What size (mm) do I need front and rear to go flush? Front and rear fenders are already rolled.
        With my previous wheels (16x7.5, ET38 with a 20mm adapter front/25mm rear, 205/45/16), my fronts were just a hair shy of flush, and the rears were just about there.
        • johnjohnsons54
          • Mar 2012
          • 228
          #5284
          I'm fairly confident it will work, but I just wanted to run it by you guys....
          I'm about to pull the trigger on 4 esm 002R 16x8 et20's and I want to to run 225/45/16's all around for a fairly beefy/flush setup. I already have a bit of fender role. I'm currently on j-stock springs but likely swaping out for IE stg 3's.
          Anything to worry about?
          ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
          In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
          I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
          • ToPLeSS(e30)FeinD
            • Jul 2011
            • 2813
            #5285
            anybody running any et 5-12, 8-9" wide wheels? looked for few pages but couldnt find anything.
            '89 Delphin 2.8 Cabrio
            '94 Yamaha FZR 600
            Originally posted by FlexdXJ
            Is that thing on air?
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #5286
              Originally posted by Thizzelle
              Mystical know of a place where I can ask fitment questions for a M3? saw that this is for non M3 and I can't find any threads on s14.net
              I doubt there's anyone as stupid as me out there. :p
              • Mystikal
                • 9602
                #5287
                Originally posted by jdirty
                Late model E30 on coilover sleeves.
                wheels are 5x120
                16x7.5 front et20
                16x8.5 rear et24
                i was aiming for something flush with little to no poke. anybody know what adapter size I could run? and possible tires? will fender work... work with the rear width?
                (From my post at what is this wheel thread)
                Smallest adapters possible. Even with, you'll be working the fenders very heavily front and rear. 195/45 F 215/40 R.
                • Mystikal
                  • 9602
                  #5288
                  Originally posted by tomsolidgould
                  Hi Jay,
                  I just purchased some stock BBS RM's 15x6.5 ET33. The lips are !/2 inch and I want to put on larger ones. I don't want the wheels to poke out. I was hoping for an E30 recommended tire size of 205/55/15. What size lips and spacer would I have to use? Would I have to use hub rings? I want the best grip and handling is there a different combination that would work better?
                  Thanks,
                  Tom Gould
                  1.5" lips F/R = 15x7.5 +20. Perfect. No spacers, no rings.
                  • Mystikal
                    • 9602
                    #5289
                    Originally posted by StreetMafia21
                    Sup my names James i just picked up a set of BBS RZ 469 Style 5 - 5x120 16x8 et23
                    what tire profile do you recommend and 5 lug adapter size in mm
                    There's a whole thread in this subsection with 16x8 Style 5 guys discussing fitment, look for it. 195/45 will be the tire of choice, along with a flat rear roll and the smallest adapters possible (18mm).
                    • Mystikal
                      • 9602
                      #5290
                      Originally posted by aPapester
                      front 17x8.5 offset 20 center bore 57.1 lip size 3inch
                      rear 17x10 offset 15 center bore 57.1 lip size 4inch
                      what tire size would be best for this and what would need to be dont?
                      205/40 F 225/35 R. Very heavy rear fender rolling along with relatively high linear rear spring rates (500+lb/in).
                      • Mystikal
                        • 9602
                        #5291
                        Originally posted by ohthejosh
                        I just bought 205 50r for my 17x7 wheels will they be meaty?
                        You will contact your front fender liners and/or rails. 215/40 is the correct size.
                        • Mystikal
                          • 9602
                          #5292
                          10mm rear. Fronts should be fine as-is.
                          • Mystikal
                            • 9602
                            #5293
                            No worries. It's tight, but works.
                            • jdirty
                              • 346
                              #5294
                              Thanks for the response. do you know how much the e30 fenders can be pulled?
                              • DTMbimmer07
                                • 1485
                                #5295
                                I'd like to know this too. I want to run 265's out back. I've already got 255's with minor rubbing on big bumps. But then again I'm also rather low.
