This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5311
    They're not quite flush in the front yet, I was thinking at least a 5-8mm in the front and a 10-15mm rear. I was at ET18 in the front with the adapters on the ACTs, and they were flush in the front.
    You will need to roll more then. Your new setup is wider, with a larger diameter wheel, and also taller. Everything to make fitment tougher.
    • Mystikal
      • 9602
      #5312
      Originally posted by ohthejosh
      Would a 15x8 et+10 with 195/50 fit and if not what would I need to do to make them fit?
      Mind you Im not lowered yet.
      Yes, they'll fit. Fender roll in the rear when lowered.
      • jdirty
        • 346
        #5313
        Originally posted by Mystikal
        Pulling is the act of bending metal. Therefore, it's pretty much unlimited. I've seen 285s all around.
        WTF285s!! but seriously, thanks for all the help Mystikal. :)
        • Nylko
          • 37
          #5314
          hey I own a 1991 E30 318i convertible I have a set of 16x7.5 et40 on original suspension set up so I'm not sure what size tires i can use. I don't plan on doing any major modifications like fender rolling but i do plan on maybe going to some JOM coilovers in the future.
          So i was just wondering what size tires i can run.
          Thanks,
          Nylko
          The Beasts of the Road and the Track!!!!!!!!!:up:
          • Jand3rson
            • 37587
            #5315
            Oh right, I didn't even think about the wider wheels...
            • bmartin
              • 15
              #5316
              what is needed to fit 245 40 17 under a late e30 with 17x8? what is the best offset? I do not plan to go low, be removing the inner liners and fitting steering angle stops
              • xwill112x
                • Jan 2009
                • 4237
                #5317
                16x8
                et 20
                H&R race no pads what tire setup expected?
                • johnjohnsons54
                  • Mar 2012
                  • 228
                  #5318
                  Originally posted by xwill112x
                  16x8
                  et 20
                  I've got wheels in those exact specs and just ordered some 225/45/16's. IMHO it's a beefy tire with decent width and sidewall that should fill up the wheel wells nicely and protect the rims while sitting pretty flush with the fender. A minor roll might be needed to run these without rubbing.....not certain as I purchased my car with the fenders already rolled.
                  215/40/16's will fit easily if you're not concerned with cramming as much rubber under there as possible.
                  ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                  In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                  I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                  • Pl3wA
                    • 1589
                    #5319
                    what is an aggressive wheel size i can run on early model fenders. rolled. slightly lowered with stock brakes etc.? im in the market for more attractive wheels and dont know much about offset
                    • keefy6
                      • May 2011
                      • 991
                      #5320
                      thanks so much
                      My old Style 5 Thread / My Swap
                      1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
                      IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
                      1998 528I (Sold) // 2003 540I ///M Sport
                      • Nylko
                        • 37
                        #5321
                        Hey is anyone there still looking for an answer
                        • JRYE30
                          • Sep 2011
                          • 465
                          #5322
                          Keskin KT1's (in the for sale section)
                          -16x9
                          -215/35/16 tires
                          -et15
                          Will this require fender rolling or fit well on a lowered 318is?
                          Thanks
                          1987 325 | @e30_hunter |
                          • Pl3wA
                            • 1589
                            #5323
                            ^im pretty sure you can run those no problem, i have 16x8's and have bout an 1" of space. and rolling just requires a rubber mallet and some heat
                            • tomsolidgould
                              • Jun 2008
                              • 14
                              #5324
                              1.5" lips F/R = 15x7.5 +20. Perfect. No spacers, no rings.
                              With the 205 50 15's will there be tire stretch? I'd prefer not to have any.
                              T
                              • dmoney(AB)
                                • 1372
                                #5325
                                17x8 m systems et 20 with 18mm adapters
                                Ideal size tires?
                                mtech1/2jzgte/r154/275tire
                                function>form
