This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5386
    Originally posted by rnw
    hi mystikal,
    need advice.. i want to create custom tin alloy wheel
    r14x8 et.11
    r14x8.5 et.5
    plan to use with sportkit springs on e28
    please advice the tire size
    thank u
    Sorry, not much info in my head for either E28s or stretched 14s.
    • Mystikal
      • 9602
      #5387
      Originally posted by Bryan///
      What is the max width tire that can fit on a 7 inch wide rim? My 205/50/15 tire ripped during the install. A local shop on my 15x7 rim
      225/50 is about the largest you would want. That rip was the shop's fault.
      • Mystikal
        • 9602
        #5388
        Originally posted by Insomniac912
        rear 16x9 et15 fronts 16x7.5et20 with 15mm spacers, just got a chance to look, sorry about that.
        195/45 F
        205/45 or 215/40 R
        • Mystikal
          • 9602
          #5389
          Originally posted by StreetMafia21
          sup, ok so i just picked up some 16x9 et12 im having them re-drilled to 4x100 .what tire profile will i need. For a nice stretch?? will i need spacers to fit the fronts ??will rolling fenders flat be ok or will I need to flare the fenders out as well??
          205/45. Just a roll.
          • Mystikal
            • 9602
            #5390
            Originally posted by GunMetalGrey
            16x9
            Et25
            DTM flares, which adds two inches out on the flares.
            Coilovers
            I want the tires to be filling out the flares, but not have to worry about rub, I can run spacers no problem.
            Same size tires all around.
            From what it sounds 245/45 with 15mm spacers all around?
            Could I get away with a 245/50? In order to get road tires lol
            I'd ask Ary at ESM. I know they did a 16x9 245 setup with flares. 245/50 is out of the question though haha.
            • Pl3wA
              • 1589
              #5391
              Originally posted by Mystikal
              Offset?
              sorry, offset is +32. pretty ridiculous. will it be even possible to use the fronts? 9.5"? if so, will 18mm spacers work and which tire size?
              Thank you
              • dmoney(AB)
                • 1372
                #5392
                17x8 et 32
                17x8.5 et 32
                215/40
                What spacers would you use
                Possible to fit a wider tire?
                mtech1/2jzgte/r154/275tire
                function>form
                • Mystikal
                  • 9602
                  #5393
                  Thank you
                  You would need an effective +6 final offset to clear, so a 26mm adapter in theory. And at that point, you'll be waaaayyyy outside of the bodywork. I wouldn't recommend it.
                  • Mystikal
                    • 9602
                    #5394
                    Originally posted by dmoney(AB)
                    17x8 et 32
                    17x8.5 et 32
                    215/40
                    Those are annoyingly close to ideal offset, which makes spacing them complicated (proper hubcentric spacers start at at least 10mm, which is too much for what you want).
                    10mm front spacer, none in the rear. 235/40 all around. The rear will be very close to the trailing arm seam and may need either a tiny spacer or a slight grinding of said seam.
                    • Pl3wA
                      • 1589
                      #5395
                      ok, i'll get 8.5's
                      so
                      16x9.5 -32 back 205-40-16
                      16x8.5 -32 front 195-40-16
                      18mm spacer
                      could i fit larger tires? or is this good enough?
                      • drumad
                        • Aug 2009
                        • 1700
                        #5396
                        mystikal, here to badger you again
                        I decided to go ahead and add flares (IE or dtmfiber) to my project car so I can fit some better sized rubber on my wheels, which are the typical brock b1 17s, 8.5et13 fronts and 10et20 rears. What can I fit now? Don't mind spacers if need be. I was going to go with newmans set up of having 245/45 and 275/40 as he had IE flares also. Any other thoughts?
                        TIA
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
                        • Mystikal
                          • 9602
                          #5397
                          ok, i'll get 8.5's
                          so
                          18mm spacer
                          Tires are too short. Go with 45 on both.
                          • Mystikal
                            • 9602
                            #5398
                            TIA
                            You already have more data on this than me. Go for it!
                            • Pl3wA
                              • 1589
                              #5399
                              OK, thank you sooo much man
                              • mbonanni
                                • Sep 2011
                                • 6236
                                #5400
                                BMW Style 4's
                                16x8
                                et23
                                225/50
                                Will it fit?
